Wear rates are most useful for specific vehicles. They don't fit averages, especially universal averages. They depend on maintenance habits, oil change intervals, operating environment, driving habits, etc. The wear rates of this vehicle are consistent across the intervals. With end-of-cycle analyses that's really what you want to see.
A vehicle that generates 2 ppm/1000 hours carefully operated in California may generate 8 ppm/1000 hours in the hands of another operator in Maine. Further, without a lot of other elemental indicators showing problems, as OVERKILL suggests, there may be some corrosion involved in iron generation based on idle time.
Respectfully, I disagree in this specific applicaiton.
The 4.6L 2v mod motors are typically very consistent in wear rates. I do agree that extreme examples can always be anecdotally shown, but overall the 4.6L is VERY proven and does not exhibit wear rates typically anywhere near this high as seen in this UOA above.
Again, I have over 600 UOAs from this engine series, seeing just about every concievable environment, oil brand and grade, severity factors, etc. I know these engines quite well. When these engines are in good operational condition, they should typically see between 1-3 ppm/1k miles of Fe, regardless what oils, filters, and use factors they experience.
Reviewing UOA Data Used oil analyses (UOAs) are tools. And like most tools, they can either be properly used or misused, depending upon the application, the user, the surrounding conditions, etc.= There are already many good articles and publications in existence that tell us how to interpret...
bobistheoilguy.com
There is a distinct difference between micro data and macro data.
The OP does not have anywhere near enough data for solid analysis; three reports are way too few to get any understanding of the average or std dev values. However, there is PLENTY of macro market data, as seen in the linked "normalcy" article, specifically for the 4.6L Fords.
We don't know what is causing the Fe to be high, but we can say with absolute assurance that the wear rates this engine is experiencing are WAY out of line with the vast majority of 4.6L engines out there. This is NOT "normal" wear.
The driving pattern here (1-2 hours) rules out massive condensation issues because it gets plenty warm enough to evaporate the moisture out. And, because engines are sealed well these days (no open PCV), there's not a lot of moisture ingestion just sitting still for long periods. He has three other vehicles with the 4.6L engine (two more CVPIs and I presume the F-150 does also). And he's mentioned that the other vehicles see less use, and more severe use, and yet have better UOAs with lower Fe. So this is NOT a matter of it just "sitting around"; otherwise we'd see high Fe in ALL his vehicles with the 4.6L engines.
To be fair, there's no reason to panic here. But the data is telling us that something is askew; it's not normal to the engine series. Rather than just brush it off, the OP should be looking for several tell-tale causes (such as the timing chain guides, and perhaps a bore scope in the cylinders to make sure there's no scuffing; and the air intake leak?). If all those potential causes are eliminated, and no issue is found, only then can he consider this "normal" for his unique engine. With only three UOAs on this 2008 CVPI, there's no where enough data to do micro analysis. So we cannot know what is average or stdev for this engine. If all common causes of high wear are ruled out by detailed investigation, then a conclusion could be drawn that this engine may have a machining defect which is simply causing high wear. It's difficult to believe that the cylinders are wearing, but the aluminum pistons are not. It's difficult to understand how a cam could be wearing, but the aluminum bearings are not (the Ford mod motors do not have the typical "babbit" bearings with Cu and Pb; they are aluminum).
This engine, despite it's high Fe counts, could last a long time just as many other 4.6L engines do. But these three UOAs are telling us that SOMETHING IS NOT NORMAL for the engine family.
