Originally Posted By: el_zorro
Im not sure anyone here has ever explained for sure what Energy Conserving really means other than many US manufacturers list it as a requirement for warranty support and that it requires API certification. Some have said it has friction modifiers (like moly). However, there are many oils overloaded with moly that are not Energy Conserving.
Is there an authority on this board who can explain to us what Energy Conserving really is and how we could identify the additives that are needed for Energy Conserving in a UOA or VOA?
I bought some NAPA 15W-50 synthetic with the intention of using it in my motorcycle. After I got it home, I noticed that the bottle says Energy Conserving (something I had never seen on anything over a 40 weight) so I e-mailed Valvoline asking what makes it energy conserving.
My question.
"I recently purchased quite a bit of NAPA 15W-50 synthetic oil with the intent to use it in my motorcycle. I didn't notice until I got home that the API donut says that it is Energy Conserving, which is generally something you want to stay away from with wet clutch motorcycles. I was wondering if you could tell me what levels of additives that this oil has?
Specifically I'm interested in Zinc, Phosphorous, Calcium and Moly. I've seen virgin oil analysis of the 10W-30 synthetic that showed no moly (3PPM, which is just noise) and I was curious if the 15W-50 has similar additive levels. Is there something else about the NAPA 15W-50 that might make it unsuitable for wet clutches?"
This was the response.
"This product does not contain any Molybdenum Disulfide additives in the mixture, but the specific Calcium, Sodium, Zinc and Phosphorus additive packages used in this product, do not allow the product to meet JASO MA specifications, which have to be met in order to be wet clutch approved oils. This product does not meet and is not recommended for use in motorcycle applications with a wet clutch property."
My guess is that it doesn't meet JASO MA because of ash levels, but I still have no idea what makes it energy conserving.
