- Joined
- Apr 13, 2025
- Messages
- 247
Please feel free to discuss anything related to Chrysler/Dodge/Plymouth minivans.
I've been tinkering around with cooling system tweaks lately and one of those is trying different thermostats...just for the knowledge.
The car has a relatively new radiator, new water pump, new radiator hoses, new radiator cap, new temp sensor, new fan relay and recent coolant flush. Keep in mind I live in a Tropical zone where we rarely ever see temps below 50F and summers are quite hot and muggy for a long time. If you live in a colder more Northern zone your cooling requirements are probably much different.
I'm doing this in a 1999 Gen 3 with a 3.3L
Recently I tried a Motorad 2340-195 "High Flow" thermostat.
After several hundred miles of driving I can't really see any significant difference over the Standard Motorad 195F thermostat for this same vehicle.
One thing I did notice was a consistent 5F increase in coolant temp at highway speeds, which is a bit odd.
It seems this thermostat is slow to open and just barely begins to open at 195F but doesn't allow a significant flow until over 200F, resulting in a warmer temp. I tested this thermostat and another of the exact same in a pot of boiling water with a laser thermometer and both opened at the same temperature (so consistency), but both are slow to open and not fully open until near 206F.
The standard Motorad 195F opens earlier, at around 192F even though it claerly has 195F marked on it. That results in a running temp of about 194F while on the highway.
I went into this knowing that changing just a thermostat is not going to do much, but curiosity got the best of me.
I wanted to try a high flow 192F thermostat but Motorad doesn't make this for a Gen 3 Caravan and I couldn't find one.
I'm also going to run the vehicle with no thermostat so I can get a baseline as to how cool it will run without one.
This should give me a better idea of how increased flow rate alters the coolant temps.
Basically, if you really want to lower the overall operating temp of your 3rd (or 2nd or 4th Gen) Chrysler minivan, you'll probably need to change the radiator to one that offer more heat rejection. I'm doing just that. Today my new 3 row all aluminum radiator for this vehicle arrives.
Will let you know how that goes here.
Note: Motorad 2040 series thermostats will not fit in 3rd or 4th Gen Chrysler minivans. The base support posts are too wide. They fit Gen 1 and maybe Gen 2.
