those ignition switches were recalled.
mine had already been done and the one i worked on had not but was not the cause.
told the owner to get the recall done.
Originally Posted By: StevieC
1) Bad spot on the starter contacts etc. Whack it with a hammer a couple times and see if it resolves.
2) Clean battery posts/terminals.
3) Check if it will start in Neutral (Bad Neutral Switch)
4) Bad Ignition Switch. Try jiggling the key up/down/all around or banging the steering column.
