So this is a little tricky. My edge, when idling, you depress the brake pedal, hold it for 5 seconds, it has a high pitched sgueal almost like an alarm. Stays squealing until you let up on the pedal. Happens every time. Brakes work fine. What could this be?
The brake pads have less than 9,000 miles. Is it the booster?
It has 132000 on the clock. The most dependable car I've ever owned.
