Originally Posted By: Gary Allan
Originally Posted By: bamorris2
Originally Posted By: unDummy
If a transmission has a parallel thermostat somewhere in the ATF flow loop, it would be possible to have ATF exit 'both' cooler lines when warm. I'll have to take a look at the r75 fluid flow the next time I see the service manual.
Most transmissions only need '1' cooler line removed for a flush. Simply knowing the flow direction is all that is needed.
Maybe you're onto something here... About half way between the cooler and the transmission, there is what I think is a bypass. Maybe it's a parallel bypass..??..
It looks somewhat similiar to the item
HERE, but is about twice the size, and is silver aluminum.
That works. With the cooler lines attached the flow would just go idle without any pressure differential. Without the deadhead, it would flow from both. Undummy called it right. If you hadn't identified a thermostat, I was going to suggest some internal wax bulb type diverter that merely bridged the in
ut ports. That would do the same thing.
When you said "each" instead of "both" (put in a jug) and "jugs" instead of "jug" ..it kinda indicated that this wasn't some imagined thing.
So does this mean that some old fluid is going back into the sump pan, since its coming out of both lines, sure surely must be going back into the pan, I would think? maybe clamp it off with a c clamp to insure flow in one direction or just remove the bypass valve temporally.
