Fluids for a 2004/2005 Acura TL
CA
Hi,
Please provide recommendations for an appropriate Manual Transmission and Automatic Transmission Lube for a 2004/2005 Acura TL.
I have the following lubes in mind:
MT- SF's MTL-P, Redline MTL.
AT- Amsoil Universal ATF
Also, what is the viscosity of Honda MTF? I know that Redline MTL is 70W-80, and SF's MTL-P is 75W-85.
Michael
As I understand Honda/Acura uses a proprietery transmision fluids. They mention in owners manuels that you may use ATF dexron III in a pinch, but you should return to the Honda ATF fluid ASAP.
J
