I was curious what everyone's thoughts were regarding flow vs. filtration. I would venture to say that generally you would want to achieve the best balance of the two. When researching various filters it becomes difficult for me to come to a conclusion. With so many different filters available in 20x1.5 (still keeping the maximum od of the gasket in mind) i am overwelmed with options. How often does a filter actually go into bypass? If a filter has a lower psi by pass will it go into bypass mode more often than one with a higher psi? If so, choosing a filter with a higher bypass will lead, in theory, to greater filtration given all others constant correct? If this is correct i would gather that there is a possible sacrifice of flow to vital engine parts. Please provide any thoughts you may have to help me make a more educated decision.
