D DaveSwan Joined May 21, 2020 Messages 122 Location Atlanta Jun 16, 2021 #1 This morning on my 08 Mariner, I started getting flashing ABS and traction control lights, an intermittent popping sound in my radio and a ticking noise under the dash. Also, the engine did cut off but was able to restart. Any thoughts?
S spasm3 Joined May 30, 2010 Messages 18,670 Location North Carolina Jun 16, 2021 #2 Check battery voltage, in case the alternator is not putting out enough juice.
B Barkleymut Joined Jan 27, 2004 Messages 4,278 Location Richmond, VA Jun 16, 2021 #3 Is the ticking noise engine related? Does it vary with RPMs? How long have you owned this vehicle? How many miles?
D DaveSwan Thread starter Joined May 21, 2020 Messages 122 Location Atlanta Jun 16, 2021 #4 No, the noise is from under the dash
M mk378 Joined Sep 27, 2015 Messages 6,762 Location USA Jun 16, 2021 #5 Check the battery connections. Also check the big ground wire that goes from the battery to the frame and engine.
zrxkawboy Joined Nov 30, 2004 Messages 3,464 Location SD Jun 16, 2021 #6 To echo others: sounds like a battery, cable/connection, or charging issue.
D DaveSwan Thread starter Joined May 21, 2020 Messages 122 Location Atlanta Jun 17, 2021 #7 Bingo to MK and ZRX. It was a positive battery câble that was by being à bit too close to the fan
Number_35 Joined Jul 7, 2014 Messages 7,807 Location Winnipeg MB CA Jun 17, 2021 #8 DaveSwan said: Bingo to MK and ZRX. It was a positive battery câble that was by being à bit too close to the fan Click to expand... Plastic fan? If steel, was it intermittently shorting the positive cable to ground?
D DaveSwan Thread starter Joined May 21, 2020 Messages 122 Location Atlanta Jun 18, 2021 #9 Yes, steel fan
