So, since this is a Toyota, I'm assuming the OP will be needing metric wrenches?
Originally Posted By: 67lemans
About two years ago I picked up a set of used Snap On for a little under 100.00
With that said, I would consider a set from SK, Proto, or Wright. I'd pass on the cheap ones. For the record, I am in no way, shape, or form a Harbor Freight hater.
wright wrenches
The SAE set you listed appears to be made in-house by Wright, but it looks like the metrics are outsourced.
This has come up on Garage Journal before. The metric Wright flare nut wrenches appear to be made by Apex Tools for Wright. That means they're the same as the USA made Craftsman, Allen and K-D flare nut wrenches. The K-D and Craftsman ones are now likely discontinued, but you can find new Allen versions and the Masterforce flare nut wrenches at Menards are USA made and are made by Apex. The ones that aren't branded Wright will also be cheaper.
Wright SAE line wrenches that are actually made by Wright:
http://www.hardwaresales.com/wright-tool...CFUcaOgodrX0Abg
Wright metric line wrenches that appear to be made by Apex:
http://www.hardwaresales.com/wright-tool-744-metric-standard-flare-nut-wrench-set-5-pieces.html
Allen metric line wrench for comparison:
I have the Apex versions branded Allen, K-D and Craftsman and they're all worked fine for me.
Another affordable, USA made option are the Blackhawk lines wrenches.
