02Lightning
wow!
Although Gary hasn't realized it yet...he's actually discovered how the Flux Capacitor works. The oil actually travels back in time and re-enters the filter for a second pass, thus raising it's pressure differential, anytime the relief valve opens.quote:
Originally posted by another Todd:
But I should point out that oil pump relief has nothing to do with it---oh nevermind!
Concurr. And my DC circuit with the variable resistor representing the engine with a function that varies resistance inversely proportional to RPMs works perfectly.quote:
Originally posted by Gary Allan:
My stance is very simple. Aside from loading (which I believe takes a very long time for most), your max potential for PSID across the filter is in a relief situation. Hence your most likely bypass event will also include the pump being in relief.
This is beginning to enter into my thicker frontal plate here. It would appear identical to my observations. In my observations of the engine side meeting and pushing the supply side pressure ..the evacuation of engine side oil would be just as valid at allowing the pump output and the engine flow to approach unity (or as close as they're gonna get in engines where the pump is always in some state of relief). In this conceptual view, reduced resistance down stream would indeed increase pressure due to having "more room" for pump output.quote:
