Not sure what is meant by trolling
![dunno.gif](https://bobistheoilguy.com/forums/graemlins/dunno.gif)
That is the distinct probability..quote:
Originally posted by another Todd:
Filter guy. In order to achieve 125psid wouldn't the pump relief valve have to be stuck shut also. That is pretty high pressure. I thought Red Bowtie stated his oil pressure never exceeded 72 psi. Now if we could figure out how many square inches that core is, we could figure out just how many pounds of force were exerted upon it.
..and here's more. Since we're sending our excess cars and putting them back in line (relief) if we get too backedup at the entrance to the two lane ..we open a "bypass" and just bridge the 4 lane to 4 lane. We only allow so many cars to recycle themselves by sending them back to the onramp. Some highways might limit it to a 8 car backlog ..11 ...heck, some allow 30 seeking reservations for transport to the promised land.quote:
Once the relief is open ..then you don't have a mandated velocity change. The flow can in deed be reduced ..you can have less "backpressure" after the filter (and do when in relief). The choke from the 4 lane to a 2 lane can mean less traffic ..the traffic after it can be less dense (less backpressure) ..because now some of the cars on the 4 lane are leaving by a whole new door.
No ..or not quite. The pressure at the point above the filter is 82 psi. The measurement below is 80. The filter adds 2 psi. If that means the same thing to you ..then fine ..but it's not truly how it is. The filter by itself ..zero "back pressure" would see 100% of the pressure developed over its resistance (it would be hard to develop much pressure ..but 100% of it would be shown over the filterquote:
OK, I'll buy that if you would say this is the same thing. If the engine produced 80psi of (back) pressure, and the filter 2 psi more, than the filter is actually producing 82 psi of back pressure, and providing only enough flow to produce 80 psi back pressure in the engine, hence 2psid.
