- Joined
- Sep 28, 2002
- Messages
- 39,793
Yes, you do get less then 100% of the pumped volume in flow. There's no two ways about this. You're incorrectly reading too much into that ONE element in the total assertion. It's because there is a parallel path that the flow dynamics change radically from a simple series "no choice" circuit to a parallel circuit where the shunt is of unknown impedence to flow.quote:
Here is what is wrong with your theory. When you increase the amount of oil "shunted to the relief" you state there is reduced flow--presumably because more oil is now flowing out the relief.
Prove this to me? That is, you've offered nothing in any descriptive fashion that this is some type of mandate. I've already, repeatedly, said that the filter bypass valve limits the amount of oil that the relief can shunt since it limits the amount of TOTAL resistance that the filter can present to flow. That is the filter/engine leg of the circuit can only drop 10 psi (in our expample)over the filter ...hence (backtracking throught the immutable formulas for pressure dedicated flow) the flow can only be reduced X amount.quote:
the engine will see the exact same flow,
I think you're just agreeing with me in slightly altered terms.
I'll continue to qualify and clarify if needed
