No Todd
I just don't check in here all that often
Okay ..
keep in mind that this is a constructed theory due to my observations of PSID and reactions with before and after filter gauges and differential gauges. I can't articulate a viable, mathmatically supported, model to satisfy my BITOG internal peer review committee ..but if you attempt to see the rationale that I'm applying, you should be able to see the "intent" of my description here.
When the pump relief is closed, ALL the oil MUST go in a straight line through from the sump to the engine. It has no other choice. It goes down a pipe. Most of us are used to our garden hoses and water faucets and think "hmmm...more restriction ..less flow". Doesn't work that way with an oil pump. 5gpm is 5gpm. As long as that pressure limit is not reached ..that oil will SCREAM through whatever you put in its path. It has NO OTHER CHOICE. It's in a single conduit (until it hits the main oil gallery - but from the pump's view ..from the filter's view
So, you can easily visualize that the engine, with all its close clearances and mass size, is going to be a major resistance compared to the filter. (figuratively speaking) Miles of oil passages ..versus one small alleged choke.
Now in series circuits ..the pressures are divided proportionally across the respective elements of the circuit. In my case, looking at a typical (warm) cold start without relief action, I see something like 80 psi post filter and 82 pre filter ...or 2 PSID. Nothing. The engine is WAY higher in resistance then the filter.
Now as the oil thins and the total pressure is reduced ...so does the PSID. The only exception is when the filter loads and increases its resistance. It changes, the engine does not. Hence you could get 2PSID min ..all the way up to the bypass limit if you left it in long enough (not likely for BITOG types ..but numb consumers that don't change their oil
maybe).
So, can you agree with what I've said so far? If you had a positive displacement pump on your garden hose ..if you tried to put your thumb over the end ..the pressure would just build to what ever it had to and the flow would remain the same. This is how pressure washers work. When you close the trigger ..the "pump relief" opens and the pump is unloaded. It just recirculates the water. Otherwise, it doesn't care what nozzle you put on the end. Open pipe ...fine spray ..pinpoint tip ..whatever.
NOW ..when the relief is open ..this is no longer the case. The flow has an option NOT to go down the pipe/hose/oil passage ..it will choose the path of least resistance until it balances the two paths. This occurs at PEAK pressure (the pump's limit). So now we have PEAK pressure ..but, in regard to what goes to the engine, REDUCED FLOW ..just like your garden hose and your faucet. More restriction ..less flow. The engine and the relief port are now in competition in comparative resistance to flow.
Now do you recall how the engine generated a "back pressure"? It represented the lion's share of the pressure generation in the reading at the guage(s). That pressure was a result of a given flow through a given resistance. This will never change. Xvisc oil a Ygiven rate will result in Zpsi. Now, with the pump in relief, and the flow reduced (some of it is going through the pump relief), it will generate LESS pressure across it.
Example: 4gpm @ 100CST results in 80 psi from the engine. 3gpm will generate 60 psi from the engine.
Okay with that?
So, now we're at our peak pressure (let's say it's 82 psi), - keep in mind that there can be 82 with no relief action ..and 82 with near 100% relief action, ..and at REDUCED FLOW. So ..one side of the filter (engine side) sees 82 ...the other side of the filter sees 60 psi (pressure generated from 3 gpm through the engine) ..for a PSID of 22. Does that add up?
BUT WAIT!!! We typically have a bypass valve somewhere in the filter circuit that limits this PSID. Hence the flow to the engine will have a max reduction due to the relief of the oil pump (or loading). Let's say the bypass valve is 10 psid. Now the engine MUST see PEAK pressure - (minus) 10PSID ..or in this case ..72 psi ..and will have that resultant flow. The bypass limits the amount of flow that can be shunted to the relief by manipulating/annetuating the max PSID that the filter can produce.
If you have no bypass valve ..there is no limit to the resistance that the filter can elevate to in "apparent" resistance. The flow can be reduced to nothing (assume that the relief appears to be a very easy path compared to heading toward the engine) to the engine and the upside pressure will be limited only by the amount of oil that the relief port on the pump can bleed off ...until you breach the media.
So, relief closed ..filter equals next to nothing plus loading. Relief open ..whole different ball game. (reread the bold type disclaimer at the top)
Further qualifications: There is surely a "chicken and egg" situation here that you can run into with stuff like this and some Boolean states in circuits (AND NAND NOR OR - and their outputs). Looking at them, you have to assign them a given status. It's difficult to take snap shots of dynamic events.
[ August 20, 2006, 01:40 PM: Message edited by: Gary Allan ]
