I accidentally bought several Motorcraft FL-839 filters instead of FL-836.
The gasket sizes and thread aizes are identical.
The FL-839 is longer but there is enough clearance to work.
The FL-836 says it has a bypass valve setting of 8-11 PSI while the FL-839 has 'none' listed.
Would it be okay to use the FL-839?
This is for a Kawasaki FD750D engine in a SImplicity tractor.
Thanks in advance for any comments.
