Originally Posted By: boundarylayer
The FL-820S actually filters quite well.
Those are half-way decent filtration specs, except the lowly Fram ExtraGuard PH2 cross referenced to the FL820S is at 95%, ToughGuard is 99%. of course the FL820S is made by Purolator and tears.... big strike against it.
The FL-820S is assembled by Purolator. Ford spec's the media. Similar to how the AMSOIL, Royal Purple...etc filters are assembled by Donaldson, Champion....etc.
The same goes for Chrysler filters which have been assembled by both Purolator and Champion depending on the year.
And yes, they are decent specs for an OEM filter (particularly in comparison to the two Japanese OEM filters also listed there) and compare well to the GM and Chrysler filter specs. The FL-820S is also a relatively inexpensive filter and has a threaded-end bypass to prevent media wash as per Ford's spec.
Also the ExtraGuard at 95% is for the FL-1A sized filter as per FRAM, not the PH2 (FL-820S) unless you are seeing something on their site I am not?
Originally Posted By: FRAM
2 FRAM Group testing of average filter efficiency of PH8A, 3387A, and 4967 or equivalent FRAM TG or XG models under ISO 4548-12 for particles greater than 20 microns
The same statement is made with respect to the ToughGuard:
And I see no mention of the actual filtration efficiency for the PH2 and TG2 listed under their respective product pages:
PH2:
http://www.framcatalog.com/PartDetailWindow.aspx?b=F&pn=PH2
TG2:
http://www.framcatalog.com/PartDetailWindow.aspx?b=F&pn=TG2
