I decided to clear next to the fence on the South side of my property. After cutting all the trees, vines, poison ivy and brush away, I used my bush hog to mulch everything up, I was almost finished when it broke.
So, being the smart guy that I am, I cranked up my Kawasaki powered Snapper mower and mulched up the rest of the stuff. Oops, I forgot about that stump. Not good.
The crank bent by 0.060 inches and the Ninja blade was seriously deformed.
Being very sad, hot and tired, I put it away. I searched and found a tool designed to straighten crankshafts. Plus a few utube video's on "how to". So, I measured carefully, marked the high and low spots and proceeded to wail on it with a 2 pound brass hammer. No luck.
So, if that fails, move up to a bigger hammer. The 5 pound sledge did the trick. After some trial and error, I was able to get the runout to about 0.003 inches. Not bad.
Then I put my brand new pretzel Ninja blade in the press and worked on that. Sure enough, it took some serious pressure, but it is now straight.
Put it all back together and it's smoother than before I hit the stump.
An oil change and some TLC and my old Snapper is back in business.
