Originally Posted By: BrianWC
Well, almost none of the 230 or so quarts in my stash, which lean heavily toward 30 and 40 weights....
Maybe I can drop in one qt of xW30 or xW40 per change....
Oh, I'm leaning toward M1 0W20, but who knows....I'm sure this thing will be fine on oil. I may just go with Supertech dino. I do plan to go by the maintenance minder...
I'm aware it makes sense to run what the car calls for, but if you are planning on driving this 'till the wheels fall off, you are unlikely to experience engine trouble that will require you to prove what oil you used.
I'd use the oils you have in your stash, b/c even if you do get slightly less mileage with heavier oils, the money you save by using your paid-for, sale-priced stash is probably a LOT more than the gas money you will save running the correct 20-weight.
If you don't do that, and stick to 20-weights for all your Honda's, what on earth are you going to do with 230-odd quarts of 30-40 weight oil you can't use?
Shame for it to all go to waste down an oil-recycling drain!
