Think about how much those screens cut flow. I'll bet if you calculate the surface area of a fine mesh screen, you will see a dramatic reduction in flow area.
Since you are using a PF52, that means the bypass is in your engine. If the screen reduces flow into the filter, you will be pushing more oil through the bypass. While I don't think you'll hurt your engine with one of these, I DO think you will end up in bypass more often.
EDIT: Not trying to criticize your choice to use the screen, or to imply that your engine will self-destruct... just giving you something to think about.
Do this: Estimate flow area of screen and compare it to the six filter inlet holes. If it is >/= to filter inlet area, than you have no worries. If it is less, I'd think twice about using that screen. If the screen is actually fine enough to trap anything, I'll bet the numbers will surprise you (just a guess... I've never used a screen).
[ December 16, 2003, 05:21 PM: Message edited by: novadude ]
