First time 12 month OCI advice
83 outside on Christmas, 30 minutes to travel 13.8 miles, BITOGers worried about engine not reaching proper temperature.
:facepalm:
Quote:
From cold if I hit the highway and drive for 13 miles at 55mph my oil temps are barely 150f. I need at least 20 miles to reach operating temp on the charger.
Clevy, unless I am wrong, you're in Canada. According to your location, the high today was 70. Almost 25 degrees cooler than here in FL. Heck at 6 AM it was 73 here.
Also, the Altima 2.5 only take 4 7/8 qts of oil. A US spec Charger V6 take 6 qts and the V8 takes 7 qts. Easy to see why it takes your oil so long to warm up given where you live and the sump size.
So 13+ miles is way more then enough time for the Altima oil to reach operating temp here in the big swamp.
Good point.
I didn't take sump volume into consideration.
Point made.
Originally Posted By: Clevy
M1 and pp are equal in my eyes and we've seen many used oil analysis where pp still had life left after 10000 miles.
However m1 is guaranteed for 10000 miles. We've seen used oil analysis here where m1 was used for in excess of 15000 miles and still had life left so the reality is both products are capable of 10000 mile drains
HOWEVER
you are driving 13 miles per trip,which is short tripping which means fuel dilution will be an issue.
So in your particular case if you want to run 10000 mile drains I'd go a grade thicker to compensate for the fuel,or forget the extended drain idea and go with a conventional at 5000 mile intervals
13 miles is a short trip to you? Uhh... don't think so. 13 miles isn't a short trip.
To the OP: If I was you, I would use Mobil 1 Extended Performance or Royal Purple with a Fram Ultra for your 1 year/10K-11K mile oil change. Extended Performance is just a few dollars more than regular Mobil 1. A few dollars for more piece of mind on a really long oil change? Worth it.
Originally Posted By: Nate1979
Originally Posted By: Miller88
Is a Fram Ultra filter a good 10K mile oil filter?
I'm just curious. I will be doing a change and running it to 10K on the Focus soon. Looking to find a filter that can do it.
Actually the Fram Ultra is a great 15k filter.
Cool! Think I will pick one up
Being in Phoenix I think about the short trip question fairly often, I'm not sure that really exists in areas like mine, or FL, TX, etc, especially if the car is garaged. In the summer my cold start is approx 90 degrees, in the winter it's probably 65. I don't have an oil temp gauge on my RAV4 but at morning startup my coolant is up to temp within a half mile, so I wouldn't be surprised if by oil was up to temp within a mile, esp if I hit a light or 2. Once up to temp, I can park for a couple hours and come back and the engine is still almost at full op temp according to the gauge.
So anyway, it doesn't seem it would take much to boil off any fuel or water. Maybe I'm wrong about how much longer it takes to get oil temp vs water temp.
Here is some rough science...I used to own a '14 Focus ST which had a water and oil temp gauge. 2.0L w/turbo.
Water temp was in normal range within 2 minutes of idle. Oil took approx. 3 miles of city driving to reach normal temp.
City driving was light take off with 3k shifts and 4 stop lights before destination.
The ST has a 5.7 qt sump.
Total drive was 4.5 miles, 5.5 if I take my son to school.
I was thinking along similar lines. In Florida the engine will get up to temperature faster than it would in a Canadian Winter. I think you can go for a one year OCI in Florida with the Ultra.
Originally Posted By: HTSS_TR
Summary, any name brand synthetic with mid-price or high end filters such as Fram Ultra can easily do 10-12k miles OCI, especially with your long 26 miles round trips daily in Florida.
This.. End of story.
