Anyone ever put Lucas Oil Stabilizer or Tufoil as additives into their T-5 trans? Using Lucas Synthetic 75w90?
I have a V6 Firebird with a Borg Warner T-5 trans, the 5 sp version of / predecessor to the T-56. I've been advised that ATF is not such a great lubricant so I'm currently trying Lucas Synthetic 75w90. I have that in my diff and it works great. At the advice of both Lucas techs and my machine shop, I am using about 10% of their standard Oil stabilizer in the synthetic gear oil in my diff. I had previously used 20% when the diff bearings were worn and it provided some cushioning. Also I like that the oil kinda sticks to the gears. It's a Torsen so no clutch packs in it, all gears.
I want to do the same thing in my trans, but I'm unsure of using additives. I've started with just the Lucas Synthetic 75W90 in my trans. I've read a lot of mustang guys saying they use it in their T-5s. While I'm sure the 1-2 synchro is a little worn, I've noticed it got even notchier shifting into 2nd with the cold weather these last few weeks. I'm here in Philly PA and we're generally below freezing right now. Of course after I drive five or ten minutes it warms up and starts shifting normally. I suppose this is because the more viscous oil warms up and works better.
Is it a smart idea to add some of Lucas's standard Oil stabilizer to my trans to improve those nibbly cold shifts? It does seem to blend well with the synthetic stuff in my diff.
I'm also considering Tufoil; in my engine, it makes these winter starts like butter. I had added Tufoil to the ATF in my previous transmission, and it shifted quite nice, but there were other mechanical issues with that one making it tough to tell what's caused by what.
If I understand synchros correctly, they spin till the teeth grab, at which point the gear is fastened to the shaft. If that's the case, I wouldn't want it TOO slippery in there cause the sychros will take forever to engage. So that's a consideration.
I called Tremec, now the parent company for Borg Warner gear, and the engineer INSISTED on Pennzoil Synchromesh. If you want the argument winner, there it is, and it's quite likely I'll be trying that out in my old trans once I have it rebuilt. But in the mean time, I can experiment with the Lucas Synthetic 75w90 on this 92k junkyard trans I scored, and that's what I'm doing. Anyone knowledgeable enough about Lucas and/or Tufoil, and the inner workings of the "World Class" T-5?
Thanks.
Thanks.
