I have had a Honda HRS216PDA for 3 or 4 years now. It is powered by the GCV160. It has been a decent mower but always underwhelming when it came to the quality of cut. I attributed it to the entry level model and features. It just didn't seem to lift the grass very well and left straggler grass blades uncut and it was annoying.
I finally hooked a tachometer up to it this spring, a whopping 2,800 RPM was all she could muster. I reset the governor per YouTube and internet research and it didn't change a thing. I attributed the low RPM to Kalifornya fuel consumption regs or just to keep noise down.
I have read/seen where guys have adjusted the spring tension on their governor arms to increase RPMs. So this afternoon I set out to experiment. My governor arm has 2 holes in it. The spring was installed in the forward most hole and didn't put any tension on the governor arm at WOT. I figured WTH and carefully finagled the spring off and put it in the second hole. This created a very small amount of tension on the governor arm.
I fired the mower up and VOILA!!! My problems were solved!!! It isn't screaming by any means but is clearly now running better. I will put the tach on it tomorrow (have to borrow it) but I suspect it is in the 3,200-3,400 range.
Man, did she give me the best cut in the 3-4 years I have owned it. No straggler grass blades left uncut and man-o-man does mulching work better now.
Before the ninnies step up and say it is spinning too fast and damage/injury will result, it isn't spinning that fast. It now sounds like every other mower in the neighborhood and isn't racing by any means.
