Filters, filters, magnafilter
4wd
$50 site donor 2026
Texas/Other via IAH
It has been almost 3 years since putting a Magnafilter in line with my XG16 remote behind LPD transmission cooler. Today I decided to open and see what I’d find. Not easy to open and not much on magnets. Decided not to spend that $40 again … and this was the 3rd magnet on this line (early magnets fairly loaded), have cleaned pan magnets 3x, and changed the 20 micron filter yearly + pan volume of ATF via drain plug
Pictures also show what I went back with.
I changed the engine oil ... XG10575 changed oil/filter early due to leak in air intake (5k on filter)
This is an unexpected filter … thought I was getting Baldwin … got (3) Sure Filter … ? Well, it was heavy, pretty decent build for under $6 … and the PRV would be up if I’d ever run on older 5.3L
Nice pics and thanks for the detailed info
Very good work 4wd...
Always good to see you on here. Hope you are kicking rear end as usual
Well, I’m kicking back something cold in the AC … had enough 96 degree weather today … but we are expecting a 91 degree cold front,
Originally Posted By: Triple_Se7en
Is that a phone camera? Really clear pics.
Tell us more about that camera.
Just an iPhone 6+ …
I use one of these filter heat sinks on my Kohler powered tractor. I don't have much airflow across the fins as the tractor is generally operated at ~ 3 mph. I figure every extra bit of oil cooling on an air cooled engine may help engine life.
Sure … they don’t cost much to buy … and work for free after that …
