doubleclutch
Thanks for all the responses! Your lively discussions on the subject brought out some great thoughts and ideas! One thing for sure though, **** happens, no matter how good a product or service is!!
I strongly dissagree with this statement. If an oil filter design was faulty. Especially in the ways that we have seen ripped and torn media. There would be no symptoms that would be detectible from the average consumer. The engine would run fine, there would be no leaks, etc. The only damage to the engine would be that internal parts of the engine would wear quicker than normal. I think we all can agree that torn filter media does not cause catastrophic failure to the engine. It only shortens the life of the engine. Thus, no heads would roll, there would be no inrush in royalty claims, etc. The end result of reducing production costs would be increased profits for the mfg. This is the American way of generating profits. (and I am fine with that) However, we are also able to cut up filters and post and discuss our findings.quote:
Filter Guy Said; If a design was "faulty" there would be a huge error rate, shut down of production, heads rolling, a huge volume of warranty claims, loss of OEM and private label business because your customers won't put up with problems, etc...
Gary Allen,quote:
That the exact same statement applies to every filter manufacturer. The likelyhood of discovery is nill with every one of them.quote:
So filter company X figures, hey we can cut cost, there will be media failures, but who is ever going to know.
Dittoquote:
The ones that may actually get cut open and show damage we will just pay the claim and get rid of them.
Simply because that's exactly what you've been installing for a very long time. Any failures will most likely be low cost Champs. You rarely see anything else. When low costs NAPA's get cycled through your clients ...most if not all your discovered failures will be NAPA's.quote:
After cutting open hundreds and hundreds of filters why are the ones failing the low end Champ filters?
I will still be interested to see what the in service defect/failure rate is for your new line of Proline. I'm sure that, on average, they will perform better than the Warner line and will contour to the added cost that they demand.quote:
And that would cost Champion Labs more in manufacturing costs to maintain a 2nd tier of QC. So, lessee - absorb the additional expense of a 2nd production line with looser QC for a product priced lower at wholesale and retail? Yep - now there's a perfect business model . . .quote:
Originally posted by ZR2RANDO:
...If Warner is the “economy” line of the “economy “ line of Champ filters, I’d bet that the Warner production line operates at a looser manufacturers spec setting than the other Champ brands lines do...
That makes cents. What are the apparant differences between a Warner and an ST/Auto Zone etc Champ?quote:
Originally posted by Ray H:
So, lessee - absorb the additional expense of a 2nd production line with looser QC for a product priced lower at wholesale and retail? Yep - now there's a perfect business model . . .![]()
That is a plausible explamation. Assembling filters with different quality components from different lines/soources wouldn't necessarily take any assembly line re-calibration.quote:
Originally posted by doitmyself:
I think I have to disagree with you on this one Ray. I don't think the companies run a second line with less quality control. I think they use the same line to make different quality products.
