Hello to all,
SO. Just when I think I have an idea as to what im talking about for motor oil my interests change…
I am ¼ of the way (locating parts can be a challenge) into rebuilding a fiat 650cc motor for a Fiat 126 ( never imported to the USA however 2k models managed to make there way over to Canada at one point)
I will be installing a traditional spin on oil filter as this motor from the factory comes with a “centrifugal slinger” as a means of cleaning motor oil… so this should aid in cleaning things up a bit if you will. Also being added from the get go is an “Abrath” xl oil pan. 4L larger factory is some where in the neighbor hood of 1L. After the build if needed and external oil cooler will be added as well.
Oil… oil… oil… Having never delt with air cooled motors I figure I should ask the pro’s.
My understanding factory fiat recommended 20w50… so to me this just seams thick… through and through… however it is air-cooled, operating temperatures for the oil will most likely be higher than your typical water cooled motor so I guess this makes sense.
Amsoil is usually what I stick with for all of my other motorized toys/vehicles and would like to stay this rout if they have something that will work with an air cooled car motor like this.
Some googling turned up a lot of VW air-cooled guys using amsoil ZRod 20w50. should I go with this?
Thanks to any and all contributions to figuring what might “best suit” this application…
Typically what I see everyone asking for are
Vehicle usage… Any where and every where 5 mile trips one way or so (however operating temperature characteristics are unknown to me at this time… I am assuming oil temperature will rise to operational temperature relatively quickly vs a water cooled motor)
oil will likely be changed after 30 min of initial start up, then again at 1 hour of operation time, and hopefully depending on what we find in the filter as well as the magnetic drain plug change the oil ever 1500-2500 miles (all depending on the first few oil analysis…)
