I was looking at a new battery I installed and noticed there is a lip at the bottom of the terminal post that can provide additional surface area for current to flow beyond the vertical surface of the terminal post. By putting a washer there you eliminate that additional surface area. Maybe the vertical surface provides enough surface area so not an issue.
I did not use felt washers but coated all areas with a brush-on NOCO chemical to prevent corrosion.
