Originally Posted By: blupupher
Originally Posted By: Gokhan
Since this engine has a known ring-wear problem, use the
thickest oil you can get away with. Rings are eaten away with the recommended viscosity in the blink of an eye. 10W-40 or 20W-50 are good choices.
It is a ring issue cause by an oil hole issue in the pistons.
Using a thicker oil, especially a xw-40 or xw-50, would cause more problems since the rings would get even less oil.
In NA, a lot of the 2AZ-FEs had certain piston rings install to my knowledge which wore down over time and the oil return holes in the piston were not drilled large enough, so deposits ended up accumulating in those holes which became blocked, made the rings get stuck and forced the oil to travel past the rings to burn up in the combustion chamber. Thats what majority of the oil consumption issues came from for these motors built in all Toyotas that use this engine from '07 - '10 based on the TSB listing. I too have oil consumption issues too but I've used full synthetic oils practically its whole life except the free oil changes from the dealer and during my oil consumption tests. I passed both times but still butn oil at roughly 1 qt per 2,800 miles according to my mileage tracking. I too agree that thicker oils may increase wear for what the motor wasnt originally designed for.
Now I also agree that the change to 5W/0W-20 oils was due to CAFE regulations requiring vehicles to be more emission friendly and better MPG but to my research, Toyota never changed the machining for these motors to compensate for those weights when prior to '07 they were all spec'd for 5W-30 oils. Newer vehicles I see the reason for 0W oils due to higher tolerances and engine design enhancements for lighter oils but those of us with oil consumption issues were pretty much left in the dust by Toyota or left hang to dry (literally with the lack of oil left).
Here's some pages i found for my '07 Scion tC manual with the same 2AZ-FE motors majority of us have with the installed oil squirters for '07+ engines. Don't forget short tripping dilutes your oil which causes it to evaporate as well which is another way of oil consumption.
