Okay, I can definitely report that I do NOT like this razor as much as my Edwin Jagger. I do, however, love the stainless steel handle, so given that the threads are the same on each razor, I've just screwed the Feather handle onto the EJ head.
If for some reason you don't like the Lord razor or the Bluebird DE blades, there are tons of other choices and prices.
You may want to experiment with some vintage Gillette Super Speed razors and get a sample pack of DE razor blades to find which one works the best for your needs. Also, certain blades work better in certain razors.
I could never get a good shave with a Derby DE razor blade until I loaded a bladed into a Gillette Fat Boy adjustable razor or a Gillette Slim Adjustable razor. Then the blade worked and I got a fine shave. Don't give up....you'll find the razors and blades that work best for your shaving needs.
