Originally Posted by LeakySeals
I moved a bunch of stuff to get to the pipe. Can anyone tell from this if its soldered or threaded?
It really doesn't matter. This went from a, "How do I get the hose off", thread. To a discussion that the OP never brought up, or was concerned with. And that is changing out valves to prevent freezing and bursting pipes. Something he never mentioned he had a problem with.
Be that as it may, from the looks of the oxidation on that spigot, it's seen a Winter or two. But seeing as you have now provided a photo of where it's located, it doesn't seem from it's location that it would be too difficult to cut the pipe far enough back on the inside, pull the whole thing out from the outside, and replace the entire spigot, along with a new section of pipe. In the process you can easily install a cutoff valve inside, like was mentioned. If you care to do so, or think it's necessary.
You can measure, cut, and soft assemble everything to assure proper length and fit. Then sweat either a new spigot, or a copper threaded connector on the outside end to accept the new spigot. (That would make it easier to replace if something like this should ever happen again). Then, after you are assured everything is cut to the proper length, you can proceed to flux, final assemble, and sweat solder all of the connections, along with the inside cutoff valve into place. I've done something like this in the past, and it's not difficult or expensive to do. The main thing to remember with any kind of sweat plumbing, is to keep everything CLEAN. And while it's not entirely necessary, I've found having a MAPP gas torch helps in getting good, leak free soldered connections easier.
