Background: The truck has about 100,000 KM on it, and it was run on 15w40 Quick Lube dino at 10-12,000 KM drains as suggested by the oil life monitor for all of its life.
Truck is located in Tornoto
I plan to:
1) Change Full-Flow Filter and add 2 bottles Auto-RX to the existing oil to clean-up residue buildup, residue wear metals, and additive clash. Run for 2400KM.
2) Rinse with 15w40 conventional for 5000KM.
3) Change oil and filter to Amsoil AME 15w40 (New Formulation), and install Amsoil BMK-17 Bypass Filter (SDF-26 FF and BE-100 Bypass) and peacock valve.
4) Change engine air filter with a new paper air filter and replace PCV valve.
Follow Up:
1) Take oil sample every 20,000 KM (about 6 mo)
2) Install a NEW SDF-26 Oil Filter, BE-100 Bypass Filter, NEW paper air filter, and NEW PCV valve every 40,000 KM. (About 1-yr)
So, what do you folks think of my plan?
How long do you think this oil will last?
The truck sees a lot of highway driving.
Michael
I plan to:
Follow Up:
Michael
