Expensive Rotella T6 5W40
Near the beach in Delaware
I have not seen any Rotella T6 5W40 on the shelf at Walmart or NAPA.
But came across this on Amazon. Unsure what the deal is, $38.90 for one QT? The picture is a QT container. The description does not say one QT or a case. It does however say 1024 fluid oz. That would be 32 QTs making the oil a little over $1 a QT.
Maybe it's listed as 1024 fluid ounces to get by some Amazon algorithm that checks for price gouging?
I have not ordered any.
https://www.amazon.com/Rotella-Synt...&qid=1652782016&sprefix=rotell,aps,122&sr=8-5
I'd bet you only get one quart. That listing is hard to get a good answer from.
If you are in need of some, do you have any Tractor Supply near you? I have seen 2.5 gal jugs for $59.99 coming to around $24 per gallon which was ballpark Walmart's price last time I checked.
I just need a QT to fill a new filter I am going to swap in shortly on my PSD. I have 4 gallons of Valvoline blue as next oil into my PSD. I try and keep the same oil type in the sump for duration of OCI to make UOA meaningful.
