Exide batteries?
Originally Posted By: Mr Nice
kplunk,
Why not buy from HD ?
As a Veteran, Lowes offers me and all Vets a curtesy discount. HD refuses to do so except for active duty. I will not honor them my business or any business that S**ts on Vets.
Originally Posted By: pkunk
The Everstart doesn't say anything about endurance from the rough road hammering. Believe me when I say I need a battery that's tough. I replace screws, bolts, and misc parts almost every travel day.
Regardless of the brand, buy a marine starting battery. Marine batteries are built tougher inside to withstand the vibration/hammering that boats encounter. They are also built to withstand deeper discharging than conventional car batteries.
If you really want a battery that will last definitely get a AGM one and make sure it is big enough. Odyssey makes great batteries.
That being said I will never buy an Exide unless it is the only option. But I get a pension from them so please buy Exide batteries.... They are in bankruptcy yet again.
I agree with you that Odyssey (Enersys) AGM batteries are the best, but they are very expensive. East Penn and NorthStar also manufacture very good AGM batteries. The quality of Optima batteries have gone downhill since JC bought them.
Exide is in bankruptcy again? You must have some inside information because it is not (currently) public knowledge. I'm not surprised since they are facing huge environmental cleanup costs due to the decades long pollution problems from their manufacturing operations, not to mention the lawsuits being filed by individuals with medical problems caused by this.
Actually Exide is bankrupt still. Been going on for 5 years or more. All US battery manufacturers went through the cleanup process, most in the 90's. At the factory i worked at making industrial batteries they went through and dug up all the dirt around the plant and ran it through a chelation process to remove the lead. FWIW Exide left the US as far as industrial batteries after their bankruptcy in the 70-80s until they reentered the market by buying up GNB(Gould) in the late 90's. All they had before that was auto start plants.
I was under the impression that Exide's distribution was in cahoots - only HD and Pep Boys seem to carry them and did they lose their OEM supply contracts with Mopar and Toyota, seeing how Kentucky-built Camrys did come with Exides under the hood while GM/Delphi and now JCI supplied their other North American plants?
Also, does Exide have operations in Europe? I would have swore that I saw a BMW-branded OEM Exide.
I do remember hearing about an English pro basketball team that had Exide as its named sponsor.
Note that Odyssey and Northstar AGM batteries have some specific recharging requirements if they are deep cycled. They like high amp recharging, and like all Lead acid batteries, like a true 100% recharge, which is not so easy to accomplish with the products available to do so, and the alternator stands little hope of being allowed to seek and hold the voltages required to do so.
These TPPL(thin plate pure lead) AGMS will be tickled to death if recharged low and slow with the often spouted 'trickle charging is best' mentality.
The Deka intimidator AGM did not do well in testing by practical sailor magazine, compared to other batteries, in deep cycle usage, as a boater would use them. Meaning many discharges back to back without a full recharge. Partial state of charge cycling is very hard on any battery, but the good ones can retain their capacity better in PSOC usage, and recover more of it when they do get the full recharge. The Intimidator did not do well and is rated by EP/Deka, at only a fraction(~1/3) of the cycles as the other brands of AGM in deep cycle service, which in my opinion, speaks volumes.
To fully charge an AGM battery, One must be able to bring it to 14.4 to 14.7v, and hold it there until it can accept 0.5% of its capacity or less. A group 31 AGM battery is around 100 amp hours so when this size battery requires only half an amp or less, to be held at 14.4+ volts, only then can it be considered fully charged. DO NOT expect that your well marketed high $$ smart charger is capable of doing this, and if you think your vehicle is capable of doing it, even on a 6 hour drive, then you are misinformed
The TPPL agms likely also need one deep cycle and the high amp recharge before they will perform their best. I could not get my Northstar-27 AGM to rest above 12.85v until I drained it to 50% and fed it 25 amps until it reached 14.7v, then held 14.7v for 4 more hours. Afterwards full charged resting voltaeg was 13.06v, and it seemed to have an engine cranking gusto that it did not have before, and this gusto is dang impressive compatred to any other battery I have used, even 2 group 27 marine batteries in parallel could not crank teh starter as fast even though their combined CCA was ~1300 compared to the Northstar's 930.
This battery now has 700 deep cycles on it, 100 of those to well below 50% state of charge, and turns 5 years old in November. Personal opinion is this type of battery is overkill as a starter only battery, and will not give the performance it is capable of unless it is indeed fully recharged often. If it is only used to start an engine, it would be like having a drag racing motor in a daily driver that never goes above 25mph. but warm and fuzzies ca be priceless too.
If the owner is going to drain the battery to 30% state of charge and expect it to still start the car at 0 degrees F, it will, whereas the same size flooded battery will not.
When Exide abandoned the industrial market in the US, mid to late 70's they went to Europe or withdrew to Europe. They are still privately owned I believe. They have always had a quality problem and Gould ran them outof business.
Exide came back into the US industrial market by buying GNB and that was basically given to them by Australian Dunlop. Dunlop was tanking due to a pacemaker recall in Asia nad neede the cash. The US at that time was dealing with the much harsher OSHA lead requirements.
At the time GNB had the industrial AGM market tied up and one of the hurdles that Exide had was the sales force was hesitant to sell Exide as their chief sales pitch had been they were junk. So now they had to start selling them in place of the GNB cells? They ended up keeping the GNB name for the industrial AGMs. Closed down all of GNB's auto start plants, there were 7 of them in the US.
Keep on if you must. I bought my battery.
AGMs do not work well as start batteries unless you can recharge them at a greater rate than most auto/truck alternators will in a standard operating cycle. Don't bother asking how I know.
EP/Deka AGMs are certainly not in the same ballpark as Northstar and Odyssey. Just look at the difference in weight alone... A group 35 X2 battery made by Northstar weighs 56 pounds vs a East Penn AGM weighs 40 pounds...
Flooded batteries made EP/Deka are very good though.
I have an industrial 12v AGM charger. It charges at near the same rate as my car. 14.8V and then tapers down.
Say one has a charger that is capable of 50 amps.
If the charger's maximum voltage setpoint is 14.0 volts, when hooked to a depleted battery, it will pump 50 amps into the battery until the voltage that the charger sees at its output terminals, reaches 14.0 volts. In order to not Exceed 14.0 volts the amperage tapers, and wil keep tapering as the battery fills as less and less amperage is required to maintain that 14.0 volts
Obviously a 50 amp charger can get the battery to 14.0v faster than a 10 amp charger, but ultimately it is the battery itself, which dictates how much amperage it can or Will accept, at a certain electrical pressure( voltage)
One can have the worlds best AGM battery, and the worlds best 300 amp charger/ alternator, but if the battery only needs 0.6 amps to be held at 14.7 volts, that is all it will accept.
The higher the electrical pressure, the more amperage can flow int the battery, upto a point.
voltages over 14.8v at 77F are fondling the extremes, but a charger seeking 14.8v will recharge a battery much faster than a same amperage charger only seeking 14.4v.
Last night I set my power supply to 13.6. the battery was 87% charged according to my amp hour counter. 12 hours later the battery was still not fully charged. My solar took it upto 14.7v, once the sun was high enough, and 2.5 hours later, after being held at 14.7v, the amperage required to maintain the battery at 14.7v tapered to 0.4, at which point my solar controller is programmed to go back to float voltage, of 13.6v.
There is lots of misunderstandig of volts and amps and battery charging. II know it was a mystery to me before I had a voltmeter and ammeter, and I made many wrong assumptions, but but but.
The battery dictates how many amps it will accept at the voltage it receives, and the more discharged the battery the more amps it will accept.
A sulfated battrey will require few amps to be brought upto absorption voltages( 14.4v+) and this sulfated battery will show a healthy rested voltage, but a small load will knock down that resting voltage to the low 12s or into the 11's, where a healthy battery will hold 12.6v+.
Beware of your charging source's green light. It does NOT mean the battery is fully charged, nor that it is still healthy.
And also remember it is the alternators voltage regulator, which controls how many amps flow, as it is trottling the alternator in order t oseek a certani electrical pressure, and this pressure is not intended to quickly recharge a deeply discharged battery, back to full.
And also, those who check their system voltage and see 14+ volts shortly after engine starting, should not assume thag is the voltage always allowed. it is likely it drops to the mid 13's in short oder, and My battery in my system, time and again,wil accept 2/3 more amperage at 14.7 compared to 13.6v.
I can change my system voltage at the twist of a dial on my dashboard and see battery terminal voltage, and how many amps are required to maintain that voltage. I can do the same with my plug in charging source, although that is limited to 40 amps, where as y alternator has 112 amps to work with, at high rpm and only when still cool. it is rated for 120 amps but at 2K rpm my engine requires 12.2 amps to power the fuel pump and ignition, and the field current dictated by the voltage regulator in order to attain the voltage I have chosen.
AGMs like higher charging rates, but their charge voltages are similar to flooded. I often shoose the AGm setting on my shumacher smart charger, when charging a flooded as number 1, it will keep the voltage, usually from exceeding 14.8v, and since it is basicaly guaranteed to bot hold the battery at 14.8v long enough, when it does drop to float voltage, much more chargnig happens at the AGNm float voltage of 13.6v compred to the flooded setting of 13.2v.
If one really wants to extract maximum batery life and performance from their lead acid battery, they need to insure that the batter yis getting fully charged, and no, your whizz bang smart fellate you afterwards alpha and omega smart charger, are not doing what you think they are, as they can't as every battery's requirements to reach full chrge, changes as the battery ages, and how it ages is dependent on how it is recharged.
Whether any of this is important to a thin plate cheapo starting battery is of course debatable, but those who do cycle their batteries deeper, more regularly, and want or expect their high $$ agm to endure, need to know what the battery requires, and generally what it reqires is more. More time held at 14.4 to 14.7v, and a higher amp charging source to get it there faster and more importantly hold it there until the battery is indeed full, not drop to 13.6v float voltage prematurely, as most every charger will do.
Premature efloatulation kills batteries, but especially AGM's.
The lesser $$ Agms recommend rates of no more than 30 amps per 100AH of capacity, but unless the battery is 95F plus when depleted and 30+ amps were initiated, I would not stress the higher than recommended rate.
The 'trickle charge is always best' mentality is only true on a still healthy battery, and only when there is no time limit on the charging of the depleted battery to actually get it full. And it is argueable that a battery drained to 10% state of charge should spend as little time as possible that low, and that a higher amp charging source should be employed even if one has all the time in the world to recharge it to 100% at a slower amperage rate.
Given that there are very few chargers out there capable of 25+ amps, and that many larger AGMS would do much much better with 40+ amps available initially to get them to 14.4v+, all the regularly marketed garage chargers are kind of a joke, and a fisting of the consumer's rectum.
Absorption voltage, is basically the maximum voltage the battery can and should be brought upto.
Absorption voltages on Gel bateries might be as low as 14.1 volts
Absorption voltage as recommended by AGM battery manufactures range from 14.2 to 14.9v
Absorption voltages as recommended bt battery manufacturers of flooded battery is range from 14.2 to 14.82 volts.
A flooded battery can be 'equalized' this is an intentional overcharge and voltage can be brought as high as 16.2v, but this should only be held auntil the specifi gravity stops rising or the amperage required to maintain 16.2 v starts increasing.
Only Lifeline, or Sunextender AGM batteries, made by COncorde, csay they can be 'conditioned' in an attempt to restore capacity caused by chronic undercharging, or recharging at too low an amperage rate when deplted regularly to the 50% range, or less. Their recommended max voltage is 15.5v, but only to be allowed after a normal full recharge at 14.4v, holding the battery there until amps taper to 0.5% of capacity.
All voltages assume a battery temperature of 77F. Colder requires higher voltages, hotter requires lesser voltages.
Chronically undercharging Lead acid batteries leads to their premature demise.
Fully contemptuous of the available smart chargers and their algorithms, i use an Adjustable voltage power supply, capable of 40 amps, and an Ammeter is used to decide how long to hold the absorption voltage I have set.
The time the battery requries it be held at absorption varies on battery temperature, the depth of the cycle, how many cycles have accumulated since its last full recharge, and the amperage rate initially applied when the battery first started getting charged. No timer based absorption stage would get it right, except under very specific circumstances, yet most every smart charger uses a timer based absorption charge duration, and most every one will fall well short of a full chrge, and that reaching that true full charge is very important with AGM batteries, especially those whose manufacturers do not condont eh c'conditioning' voltages when capacity has obviously decreased.
As far as Northstar and Odyssey, well Odyssey's capacity recovering procedure is to drain the battery to 10V under a relatively high amperage load, and then recharge at a 40% rate, 40 amps for a 100Ah battery, until 15v is reached, and then held until amps taper to near Zero, then repeat.
I have not gone anywhere near this far, but when my NorthStar AGM starts underperforming, based on voltage held under load for a certain amount of capacity removed, the high amp recharge from a well depleted state returns performance. It is a 90 AH battery, I can lug in 2 charging sources for 65 amps of charge rate. It will accept 65 amps for 22 minutes from 30% state of charge before voltage at battery terminals rises to 14.7v, and then it requires 5.5 more hours held at 14.7v before amps taper to 0.45 or less, and the next discharge cycle the voltages it holds are significntly higher than before the high amp reharge, and it is not just because the battery is still warm from the high amp recharging as the next nights discharge and the next dozen the voltage held for AH removed are still superior to before the high ampo recharge.
Beware of the 'trickle charge' mentality, but especially so on Lead acid batteries that actually work for a living.
I care for My AGMs with some of the best charging and monitoring devises available & agree with your post.
http://www.bestconverter.com/Boondocker-...ml#.Wu0kH9PwbFw
http://www.bestconverter.com/Trimetric-2030RV-Battery-System-Monitor_p_557.html#.Wu0kONPwbFw
I like Powermax Converters as a brand, but more so their adjustable voltage models. I would prefer that their 3 and 4 stage automatics versions seek that 14.6v, and hold it for longer than 15 minutes before reverting to 13.6v.
If it stayed up at 14.6v, full charge on 200AH of still healthy AGM depleted slightly below 50% could likely be completed in 6.5 hours, but since it only gets them to 14.6v and holds that for 15 minutes, then drops to 13.6v it will take 12+ more hours at that 13.6v to get up near 100%. If the next discharge begins in the 98% charged range, that is a partial state of charge cycle, and the battery capacity will walk down faster than if it had reached 100% SOC before the next discharge cycle began.
The trimetric battery monitor needs to be calibrated properly and occassionally reset when the batteries are known full. They are also easy to wire improperly. No wires should goto battery (-) that do not run through the 500 amp shunt. I've found several systems where the shunt was not counting all the loads, and as such the owner did not realize that they were severly undercharging the batteries, as the monitor was not counting ALL the loads, and their charging sources were stopping well short of the 100% goal, but the trimetric was reading 100% saying all was fine, when it was not.
Those interested in this topic of amp hour counting battery monitors, can read more here:
https://marinehowto.com/installing-a-battery-monitor/
https://marinehowto.com/programming-a-battery-monitor/
With RV converter/ chargers, I am partial to the Progressive Dynamics 9200 series, as with their 'charge wizard' one can override the 3 automatic voltage setpoints. Press the button once and it will seek, with its maximum amperage available, the 14.4v absorption voltage, and hold it for 4 hours. One can also force 13.6 or 13.2 with the same device.
PD has also come out with a -14.8 model as deep cycle batteries like Trojan recommend an absorption voltage of 14.82v. One can get these in 45/60, 70 and 80 amps flavors, though the 70 and 80 require a 20 amp household outlet. Cut a set of 6AWG or thicker jumper cables in half, install them in the converter, and these RV converters will easily outperform one of the wheeled chargers that some put so much faith in, and be a fraction of the size and without the danger of bringing a battery over 15 volts at high amperage, which is very abusive, though effective.
Powermax adjustable voltage versions are power factor corrected in the higher amp versions, and they can go as high as 120 amps DC output if special ordered, on a 15 amp household outlet that is delivering closer to 120Vac. This 120 amp charger is about 12 inches long 6 wide and 3.5 tall. One needs to provide their own DC cables to battery.
You're not comparing apples to apples. The East Penn group 35 AGM battery is a 680CCA at 40 lbs. and is equivalent to the Northstar ELT-ACE35 at 675CCA and 42 lbs.
The Northstar NSB-AGM35 is 740 CCA and weighs 48 lbs. (not sure where you got 56lbs??).
Is this the study you reference: https://www.practical-sailor.com/issues/32_3/features/Deep-Cycle-Battery-Test_5244-1.html
It is from 2006 and has some implied flaws like many magazine reviews.
- Regarding the DEKA, their website infers that the Intimidator is is a combination starter/deep cycle battery that will provide moderate starting and deep cycle performance: "Best all-purpose service provides starting, cycling, and deep cycle capability"... http://www.eastpennmanufacturing.com/wp-content/uploads/Marine-Battery-Application-Brochure-0149.pdf
The Practical Sailor article states that the DEKA is "adequate" and "Our Budget Buys, the Deka batteries, will satisfy money-conscious sailors who want to upgrade, but don’t need the very best." Not quite the same as your "did not do well in testing".
The article rates the Mastervolt AGM 31 the best. When you go to Mastervolt's web page, they imply that their AGM 31 (only 90 AH) is a good starter battery with mediocre deep cycle capability. They promote their Gel battery as their top deep cycle battery. Something doesn't add up. Why the discrepancy between the mfg. and the article? https://www.mastervolt.com/store/ "Their construction gives a very fast discharge at very high currents so AGM batteries are ideal for systems that require high currents (for instance when starting an engine)...Also for medium cyclical use."
In your PM to me (thank you very much, again) you stated that Lifeline makes the best AGM batteries. The Practical Sailor study ranked both Trojan and Mastervolt better than the Lifeline. Again, it makes me wonder.
When you look at this information, it seems that the DEKA is an o.k. battery for what it is, but if you want to pay more you can get a better "real" deep cycle battery. I also wonder (don't know) if manufacturing has changed since the 2006 comparison. I would think that mfg. have had to change their manufacturing to meet higher environmental regulations (speculation). And now China is in the picture also. Just my observations.
pkunk, enjoy your new Exide battery and please follow up with your results.
The test I was referencing was also testing Northstar and Odyssey AGMs, so I believe it was a later test than the 2006. Every time i tried to read it they asked for a username and password, so i was taking my info from some I trust who summarized the results of it.
The SAE J537 storage battery Reserve Capacity Test implies a 25 amp load and how many minutes it can provide that until 10.5v is hit.
If I were being paid to compare batteries using this test, I would want to see how many times the battery could actually perform the test, not how many actual minutes it could provide 25 amps for the perhaps half dozen times as they tested the battery.
Eitherway there is a huge difference in what a pure starting battery is asked to do, compared to one that is asked to deep cycle day after day back to back.
I will stick with my opinion that the Lifeline AGM wll out deep cycle any other AGM battery, all factors being equal.
Lifeline also market AGM starting batteries, but their weight and specs seem to indicate they changed nothing internally compared to those they market for deep cycling. Not sure what is up with that, other than to blame marketers and accountants.
I am impressed with my Northstar AGM in its current dual purpose role, and would buy the same again if it failed tomorrow, but it will not fail tomorrow. The voltage it holds during discharge are still impressive at 4.5+ years old and 700+ deep cycles and several hundred semi shallow cycles and several thousand engine starts.
Anyway, East Penn Deka are a good outfit. Their Deka intimidator AGM is about the same price as an Asian made AGM from UPG, but its made in the USA.
The Intimidator is not intended for pure deep cycle usage, I am sure they could make an excellent pure deep cycle AGM, if they saw the market for it.
Beware of marketing. The basic flooded marine battery in the regular car jar sizes, even though it will proudly say 'DEEP CYCLE' in big bold letters, has plates less than half as thick as a genuine lead acid deep cycle batery such as the GC-2 size group, GC meaning golf cart, and these are 6v meaning two in series must be used for 12v. If a manufacturer tried to stuff thick deep cycle plates into a 12v car jar size flooded battery the CCA figures would be so low it would be nearly useless for starting, and be so acid starved it would be difficult to recharge fully in a reasonable amount of time.
AGMs can blur the line between starting and deep cycle in the regular car jar size groups.
I recently installed a Crown1 group 31 AGM as a deep cycle battery in a traelling couples van, and Crown does not even list a CCA spec for this battery. It also did not hold very impressive voltages powering 400 watts of load in my testing, which lends creedence to it being a dedicated deep cycle AGM with No CCA rating. My well aged and used Northstar would outperform this new larger heavier higher capacity Crown1 AGM in voltage held for the same high load. But the Crown1 would likely outcycle the same size Northstar in the same usage and recharge regimen.
Anyway, this is an Automotive forum and very few readers here have a need for a battery which can handle deep cycling, or should base their battery purchasing decision on a battery designed to handle deep cycling duty.
Readers need to know that LEad acid batteries ALWAYS, want to be returned to a true 100% full charge ASAP after any deletion, and kept cool. The worst battery kept fully charged will easily outlast the best battery chronically undercharged. Reports of battery longevity comparing one brand against another, without any indications of how well either battery was recharged or how hard I was used, are nearly entirely useless.
But a battery brand which is known to quickly grow fuzz from the terminals no matter how much care one takes in properly torquing the post clamps......
Long ago I had one Exide Nautilus marine battery, which just spewed Acid from the caps no matter what charging voltage it saw, and I read several reports from others of leaky batteries and asked if they were Exide Nautilus brand, and they were like How did you know that?
But that was 15+ years ago.
My finger hit the 5 not the 4.....
Both are AGMs... But like you said there is a difference between the two. Which is very true. The Batteries Plus AGM I can easily get a half a mile away from me was the one I was thinking be of... The X-2 AGM. Which is closer to the NSB-AGM35. But not the exact same though.
The Northstar battery made for Batteries Plus the X-2 group 35 weighs 46 pounds basically aka 45.6 rounded up to 46... This battery is the dual purpose deep cycle/starter battery sold by Batteries Plus.
Looked Northstar group 35 agm battery NSB-AGM35 on their website...... 880 CCA at 0°F..... Battery weighs 22.2 kg which equals 48.84 pounds rounded up to equals 49 lbs..... So, they make their own battery even better than the X-2 they make for Batteries Plus.
I walked by the Exide rack at Home Depot a couple of weeks ago. Every one had white fuzz at the base of the terminals.
Ed
