Originally Posted By: tinmanSC
I was changing my neighbor's oil today in their 2000 Ford Windstar with 122K. When I drained the oil out it was very very black. I know color is a poor indicator of oil life, but this was blacker than black. I was quite surprised. As I was draining the oil, I unscrewed the drain plug and the oil started to come out. I turned away for a second to get a Blackstone oil sample container, I turned back, and the oil was done draining. I got less than a quart out of the engine. I drained the filter (STP model S3600) and I got just under 1 quart of oil in total from the oil and the filter. This engine with filter takes about 5.5 quarts.
I'm a bit concerned about this. I understand they even added oil to this engine since the last oil change (the engine has been using high mileage oils for some thousands of miles). This is a great deal of oil to loose. There appear to be no leaks around the engine, so I assume the engine is burning the oil. I drive the van from their house, right next door, to my house and the oil light was not on.
I guess any advice would be helpful. This seems kinda nutty!
Change oil and filter often - until you notice better looking black oil when draining.
