Last night I changed oil in '04 Honda S2000 with Mityvac Fluid Evacuator Plus model MV7201. I checked the oil level the day before, it was full and the sump is 5.2 quarts.
The Mityvac could suck out only 5.0-5.1 quarts because it is hard to feel the bottom of the oil pan with plastic tube. The car also has Fram Sure-Drain, so that I tried it to see how more oil can be drained via Sure-Drain. Without raising the front driver side, about 5-6 ounces was drained after 10 minutes. Raising the front driver side with OE jack (drain bolt is on passenger side that can be reached from the top), another 3-4 ounces was drained after 15-20 minutes.
I then removed the oil filter, another 10-12 ounces of oil was drained from oil filter and from filter mounting hole. But there was some oil left in the filter itself, my guess is about 5-6 ounces.
Conclusion, changing oil+filter for S2000 using oil extractor can leave up to 9-10 ounces old oil in the engine compares with drain oil from drain bolt. Change oil without changing filter (specially without removing filter) even using drain bolt can leave as much as 1/3 to 1/2 quarts old oil in the engine. This doesn't count old oil in various parts of engine that can not be removed by any mean other than tear down the engine.
Honda S2000 is very easy to change oil+filter because both drain bolt and filter can be reached from the top, with Fram Sure-Drain installed it can be done without jack up the car.
