- Messages
- 33,976
- Location
- Southern NJ
Changing the oil can be messy. Has anyone used the Fram sure drain? It is a nosle that connects to a bolt that you put in place of the original drain bolt your car came with. I saw it a Pep Boys today. I also am giving up on the exact fit sockets thata fit on to your socket wrench for your oil filter. They tend to slip. I might try the wrench with the adjustable loop at the top that will fit multiple filters.
