excellent diesel oil comparison tests
Illinois Valley
Figure this is a good community to share this with...hopefully not a repost
http://www.turbodieselregister.com/TDR57_Oil.pdf
It made me switch from rotella t6 synthetic to valvoline 15-40 premium blue due to the grat additive package....I know its got that big Ol C on the bottle, but hopefully the Ol stroker likes it
Interesting article, but I think I missed the key part where he explained how a lube's performance in an engine can be determined by analyzing the add pack... doesn't the BITOG UOA section seem to contradict the whole premise of the article?
yeah according to the chart the VPB has about the same add pack as t6, but with a spash of boron and moly.
TDR puts out some great articles, unfortunately this one is a little dated.
T6 and VPB are now CJ-4 rated (most off the shelf HDEO is now), and as such the add packs have changed.
either way T6 and VPB are both high quality HDEOs
First, welcom to the site!
Now for a dose of reality ...
What you are reading there is typical uniformed bias. They are presuming there is direct relationship between inputs and outputs, as if there was a 100% assurance based upon that theorm.
As I've said hundreds (perhaps thousands) of times, inputs are interesting, but results are what matters.
When you run any of those fluids in "normal" comparitive circumstances, you'd find precious little if any statistical difference between their actual abililty to protect the engine from heat, wear, contamination control, etc.
VOAs are predictors; nothing more or less.
used oil analysis are results, and reveal clear performance capabilities.
I would challenge anyone to show me how the product ranking that the article touts can actaully be replicated in real world results. I'll cut right to the bone; I triple dog dare ya!
While I , for the most part, agree with most of what you post there is an asterisk needed here.
Having owned a 6.0 powerstroke since early '04, and prior to that 7.3 powerstrokes, lube choices, more specificially add-packs do matter. With the HPOP system these trucks employ many lube choices fall woefully short on going the manufacturers OCI's.
Our own HDEO UOA section is evidence enough to make my point.
I have a file full of used oil analysis that tend to agree with what will be found in the HDEO section.
In my own experience the Shell Rotella T line is an average oil, nothing special. It works just fine in almost all applications, but when you add in an HPOP system to the equation it falls flat on its face.
The number of people who had been using T 15w40, and then experienced injector issues are alarming, and then switched to the 5w-40 variant and their problems went away.
These same guys all swear that you cannot use conventional lube in these trucks, there is nothing further than the truth.
In my own truck I have used 10w30 for the last several years without issue, stellar used oil analysis, and going the manufacturers OCI.
I guess this means I have sort of accepted the "triple dog dare". hahaha
Please clarify. First you say that additive packages make a difference in HPOP systems, then you give an example that suggests that viscosity differences affect oil choice for HPOP systems.
Plus, this statement from Stealth Pumps, makes me think there are many other variables that might affect oil longevity in modded engines. So, how safe are we to assume that oil formulation alone is the issue. Do the used oil analysis divulge any mods? I know nothing of this stuff, just saying.....
Per Stealth Pumps:
"The HUEI injection system that the 7.3L Powerstroke utilizes is a brilliant injection system, with one
flaw. If you change one of the injection system variables such as an aftermarket computer chip
and/or a set of aftermarket injectors the factory HPOP (High Pressure Oil Pump) cannot keep up
with the demand. The problem in making serious horsepower with the 7.3L Powerstroke is the lack
of oil volume supplied to the injectors when one of the injection system variables is pushed past the
stock parameters. Have you ever noticed that 50% to 75% percent throttle feels just as powerful as
putting your foot to the floor? That is because you are losing oil volume to the injectors."
Per Stealth Pumps:
The point I was trying to make is this; Rotella doesn't seem to hold up as well as some of the other oil choices, and it surely didn't in my application.
My appolgies for not making myself clear in this aspect. In my own used oil analysis 10w30 does seem to hold up quite well.
In my application 15w40 (Deere Plus 50 II) held up quite well with 7,500 mi. OCI, it never sheared out of grade and wear metal counts were always low. The reason I traveled down the avenue I did was after reading several hundred posts here and elsewhere I was looking for improved fuel economy when fuel prices spiked in '08.
I made the switch to Rotella 5w-40 for three consectitive runs and my used oil analysis were sub-par, increased wear metals and viscosity dropped to a low 30 wt. vs. the 15w40 Deere lube I had been using for years.
Then after seeing the results Dnewton, among others were having with 10w30 in truck applications I made the switch and will use this grade as long as I have a 6.0.
Wear metal counts dropped back to where they were prior to my use of 5w-40 and viscosity, although it did shear, has never went as low as it did with the Rotella.
So after trying to explain my story, in my use 10w30 works very well for me, and I beleive the 6.0 almost prefers a 30wt. vs. a 40wt. Some additive packages seem to hold up much better than others in the HPOP system, I have my own used oil analysis as exibit A, among
the many others posted in the HDEO section.
I have never investigated the difference in additive packages in the Rotella 15w40 vs. 5w-40, but for whatever reason the 6.0 guys seem to rave the 5w-40 version.
So, for you the John Deere Plus 50 II 10W30 might be nirvana?
Thanks. I see that there are two issues here, I think. For some, the switch from 15w40 to 5w40 solved the injector issues. But, you noticed that the Rotella 5w40 was giving less than excellent engine wear numbers, oil longevity, etc..
That is an old article. I really like the TDR website and everything they do over there, but when that article came out I found it very biased since TDR articles are written by its fanbase of ppl or forum sponsors for their quarterly newsletter/mag.
What 10w30 specifically are you using? I have available to me, Chevron Delo, Rotella T3, or T5, and Brad Penn. Are you recommending John Deere?
Yes, it's an old article. If you want the VPB now that has the same specs as back then, you need to be buying VPB Classic, which is not CJ4 rated.
So many opinions on all this. Do the engineers for the manufacturers go thru the same discussions/arguments as to what's best? Is there no consensus amoung them? Are we all floundering around that which has already been gone thru by those who should know so much?
When I bought my 2002 F150 the manual said to use 5W-20 which seemed really pushing the limit for me but I trusted them and used the stuff at OCIs of 5k thru 240k miles without problems before I sold it. At the end it was going thru 1.5 quarts between changes. Not bad, it made a believer out of me. Now my new 2011 F150 Ecoboost's manual says I'm to use 5w30. Dang, I'd just become a believer in the 5W-20. Seems crazy, but I'll trust them again.
I do a great deal of work for the railroads who don't believe in trying anything new until it's been proven for about 30 years. When I was young it was tough for me to accept this policy, now that I'm older, I'm a believer. It's hard for me to flip flop on all of this and hear such varying opinions. Perhaps, it's not really so since each engine has minor nuances that need to be handled.
I'm ever learning, and never able to come to the knowledge of the truth.
Anyway, what I'm really struggling to know is what's the best cost/benefit oil for my 2007.5 6.7 Cummins with deletes that I push very hard pulling a 17,000# horse trailer all around the country?
Jessep: You want answers? Kaffee: I think I'm entitled to them. Jessep: You want answers? Kaffee: I want the truth!
...me, too.
The truth? Can you handle the truth?
Look over the multitude of used oil analysis we have here. There are occasions where some relationthip of engine/oil may not fare well, but very often that is not the oil's fault and any lube would be challenged. But the VAST majority of used oil analysis show that today's lubes are very capable, far more so than many would give credit for.
There is no "best" oil. The sooner you realize that, the easier your trek will be. That is the truth. What can be said is that there are many lubes that will be "better" in any given situatation, unique to each application. Most systems and situations are more than well served by traditional CJ-4 conventional oils. You would have to experiment with many OCI/UOA combinations to find a "best" oil, but you can be assured that just about any HDEO is going to be well more than good enough for what most would be put through.
There are some examples where an ISB is paired with VPB conventional oil and running near 20k miles per OCI, with only full flow filtration. Can that be done by everyone? Probably not. But the point to understand is that some engine/lube combinations are much more tolerant that you'd think.
OTOH, there are some combinations that end up confounding the user, and cannot seem to be recitified no matter how much effort/money one puts into it.
As for cost, that is the wild-card. Some people seem to be able to ignore oil that runs $9/qrt, as if it's water under the bridge. Others (me) cannot avert the reality of ROI; I don't mind spending money, but I do mind wasting it.
You want the answer?
There is no "best" oil for everyone. There may be a "best" oil for you, but you'll have to spend a lot of time and money finding it through experimentation and diligent tracking.
I want the truth and I fully agree with you. It will be interesting to see where the oil technology goes from here. What's the CK-4 going to be like....?
It's been fun. With that, I quit.
there is always something better and oil is no different.the above statement is purely ,with all due respect,denewton's opinion!!! we all can go on and on but the fact is alot of oils are made better then others.one has to do their homework and find that brand of oil...this is my opinion too and what i have learned..
PC-11 is the new proposed lube standard with the API.
http://www.hddeo.com/IntroducingPC-11.html
good links in this.
Of course, there will be some who will lament the usupration of CJ-4 ... claiming that the "new" oils will not be as good as the outgoing ones.
There is no "best" oil for every situation. There are many great oils for specific situations.
"Better" is like beauty; it is in the eye of the beholder ...
The simple version is whether one oil is better than another does not mean you will get the benefit out of it. Some consider synthetic to be a bit more tolerable in certain areas, whether or not it's put to use is a function of use seen or an event.
Let's not confuse the oil vs oil debate with thinking it directly translates to long-lasting engines in of itself; if the same vehicle is cared for well and the oil like any other tool is used correctly based on the applications needs and the 'definitively VARRIED' lube types(read, tools).
Don't use tools incorrectly.
