Hi all, another question from a newbie here. My Corvette calls for the new Dexos 2 certified Mobil 1 ESP 0w40. As I understand it, Dexos 2 is a low-SAPS formulation which is meant to protect emissions systems, hence the "ESP" in the name of this particular one. I also understand this formulation is meant to be better for GDI engines as it should result in less build-up on the valves when vapors come back through the PCV system. So as I'm looking at alternatives to the Mobil 1 0W-40 (nothing against it at all, I've always been a big fan of Mobil 1) for maximum protection of the engine (as opposed to the catalysts), I keep coming back to Redline 5W-40. Thanks to all on here who have recommended it. It's not Dexos 2 nor a low-SAPS. But it has a very low NOACK of 6. Seems to me that with such a low evaporative loss, it shouldn't be sending much vapor (with the offending SAPS) back through the PCV system. Secondly, from all I've read, ester base oils are the "best" at protecting and keeping the engine clean, so how would you balance this vs. the need for low-SAPS. Thanks in advance for knowledge and insights!
