Originally Posted By: d00df00d
Originally Posted By: Tom NJ
Originally Posted By: dparm
When is it "too much" ester for non-race use?
Depends on the ester and the intended use. My only concern with esters in street use is seal compatibility, so I prefer to balance the ester with an equal amount of PAO. Water retention is not an issue, nor is oxidative stability. Natural esters such as vegetable oils lack oxidative stability, but synthetic POEs are more oxidatively stable than PAOs.
Some esters are friendlier on seals than others, but these are usually high molecular weight esters with lower polarity and are not as suitable for 0W-X or 5W-X street oils as lighter esters. One of the most popular POEs used in motor oils is "C8C10 TMP", which has the following physical properties:
Visc @ 100C = 4.4 cSt
Visc @ 40C = 19 cSt
Visc @ -40C = 5,600 cSt
Viscosity Index = 140
Pour Point = -65F (-54C)
Flash Point = 490F ((254C)
Noack = 3%
Density @ 15.6C = 0.95
This ester has very high lubricity and is contained in some jet engine oils, but seal compatibility is a moderate concern for me. When balanced with some PAO, however, I have no worries and it becomes an ideal base oil for motor oils. I wouldn't hesitate to use it up to about 40%, with 40% PAO. Above that a series of seal compatibility tests would be prudent.
Tom NJ
What a shining example of the kind of post that has been far too rare at BITOG. Thanks, Tom!
I have to say, it is much better than my "just use YBP" comment I usually offer.
