Motul 300V Ester Core oil launched
Frisco, TX
Pretty sweet video but it doesn't reveal much about the product. Joey at Motul USA had been talking about this for a while.
An article that details the launch:
Launch in Sri Lanka
As you can see, they've added 0w15 and 0w40.
They're also adding an anti-tamper seal with a serial number you can verify online. Perhaps they've had problems with counterfeiting.
I'm not 100% certain what was changed based on this statement:
Motul’s R&D department focused on new formulations, placing esters at the center of its strategy, combining the latest 100% Motul base oil and new additive package. This complex and performing combination is held in each lubricant under the name of Ester Core ® technology, an evolving technology based on the Esters harnessing for over 40 years.
Here are the specs for the new "Trophy" 0w40:
Density: 0.848
KV @ 40C: 75.7
KV @ 100C: 13.6
HTHS: 3.9
VI: 186
Pour: -51 C / -60 F
Flash: 222 C / 432 F
TBN: 8.25
Here are the specs for the new "Sprint" 0w15:
Density: 0.838
KV @ 40C: 23.3
KV @ 100C: 5.1
HTHS: 2.0
VI: 155
Pour: -60 C / -76 F
Flash: 230 C / 446 F
TBN: 7.97
They also posted up an interesting graphic showing oil pressure when 300V Ester Core was used at LeMans this year:
Additionally, some of the other datasheets have been updated.
For some reason they all show TBN of 8.25 (except the 0w15 and 5w30 which are 7.97). This is a drop from the normal 10-12 range.
Some are seeing a drop in VI and HTHS, while others have seen them go up. Then again, these are just specifications and the real proof is in the pudding.
High-RPM 0w20
(VI has dropped, but HTHS has risen)
http://www.motul.com/system/product_descriptions/technical_data_sheets/51781/300V%20High%20RPM%200W-20%20(GB).pdf?1329125318
Power Racing 5w30
(HTHS is down slightly, VI is up slightly)
http://www.motul.com/system/product_descriptions/technical_data_sheets/51784/300V_Power_Racing_5w30_(GB).pdf?1339171623
Power 5w40
(HTHS is down to 4.1)
http://www.motul.com/system/product_descriptions/technical_data_sheets/51783/300V%20Power%205W-40%20(GB).pdf?1329125425
Chrono 10w40
http://www.motul.com/system/product_descriptions/technical_data_sheets/51779/300V%20Chrono%2010W-40%20(GB).pdf?1329125493
Competition 15w50
(VI is up, HTHS is unchanged)
http://www.motul.com/system/product_descriptions/technical_data_sheets/51780/300V%20Competition%2015W-50%20(GB).pdf?1329125523
LeMans 20w60
(VI is up, HTHS is down)
The specs for that Trophy 0w40 are the best I've ever seen for a 0w40. They have the same KV values as Mobil 1 0w40 but with a higher HTHS. This should make it even more shear-resistant.
While Redline 0w40 still has a higher VI, it is also thicker with higher KV values and HTHS of 4.0. The same can be said for Liqui-Moly Synthoil Energy 0w40 which has higher KV values but HTHS of only 3.6.
dparm, thanks for posting this.
Nice to see an oil lighter than the 0W-20 with the addition of a 0W-15; though disappointed in the VI of only 155. That means it's heavier than Sustina 0W-20 at 0C although it is 10% lighter at room temp's.
Don't like the VI drop in the 0W-20 or the higher HTHSV.
They need a 0w30 although the lower HTHSV and higher VI of the 5w30 is a nice improvement.
Yes the long awaited 0W-40 is a nice addition with it's respectable 186 VI. A bit heavier than the SN Mobil 1 0W-40 and lighter than Red Line 0W-40 although not likely noticeably due to the higher 197 VI of Red Line.
Nice to see a more reasonable 4.1cP HTHSV for the 5W-40 grade. Never did believe the previous 4.5cP figure.
Density used to be at .89 (pretty regular for an ester) before and now is down to .86.
Why would that be?
I think it's a combination of thinner base (hence the pour point down from 36 to 45) and much more polymers hence the lower HTHS.
The ester % is probably less than 50% (just like on the previous one)...I have to find the MSDS...unless someone here has it.
Thanks for posting all this. Is there a way we can get some safety data sheets? I can't find the website you got this from. In which country/website was it launched ?
Red Line also has a better pour point.
Pour point is of virtually no importance other than trying to determine base oil make-up and is a misleading spec' at best. Yes RL has very low PPs but their oils do not have especially low MRV stat's at all and are not good extreme cold performers.
Of course this is usually totally academic in a high performance oil.
I totally agree. I mentioned for the sake of base oil debate:
diester vs polyolester :-) even though I think Motuls's PP is due to grIII base in there.
I personally like the lower TBN...
They sure get very close to RedLine specs.
You think 300V uses GP III oils? I don't know but would be very surprised if they did in their top line race oil.
PP is not a reliable indicator of the quality of the base oils used. NOACK is but Motul doesn't give volatility figures IIRC.
Group III might be a carrier for additives. I doubt it's in any significant quantity.
For some reason the MSDS sheet on their website keeps redirecting me to the homepage.
Grp III is a poor carrier so that isn't the reason. In fact Esters are very good carriers in and of themselves. I would not pay for their 0w40 over Mobil 1 0w40 anyway.
Just talked to a supplier, they said Ester Core probably won't be released until the regular 300V inventories are depleted.
Interesting. That's the 5w40. I wonder if the other varieties are very different. Do you have the old MSDS?
With Motul 300V at more than twice the price of Mobil 1 0W-40 I wouldn't either.
In fact with Red Line being relatively cheap here in NA, it's hard to beat in an ester based oil over the more expensive Motul. I'd prefer Red Line 0W-30, 0W-40 and 5W-50 to all of the 30wt and heavier Motul oils. With HTHSVs ranging from 3.2cP to 5.6cP and a VI no lower than 183 you can mix and match to make whatever you want in that viscosity range.
