I had this UOA done at Wearcheck Canada due to a concern with condensation (see my previous post).
The oil is the Esso XD-3 0W30 synthetic that's getting a lot of attention. The oil was in service from mid November to late January for 11,155km (7000 miles). The car had 76,665km when the oil was drained. The car is driven 75km each way to work (all highway with little/no traffic). Average speed is 100km/h. The Grand Am has the same engine as olympic's Montana which also has been using the same oil (see his UOA here).
Here are the results
Silicon 21
Potassium 0.9
Sodium 3.4
Fuel Glycol NEG
Water 0.179%
Soot ---
Sulfation 54
Nitration 53
1st column: Current, 2nd column: Base
Boron 3.3
Barium 0.2
Calcium 3108 3800
Magnesium 25
Molybdenum 2.8
Sodium 3.4
Phosphorus 918 1350
Sulfur 3191
Zinc 1157 1500
Visc@40°C --- 71
Visc@100°C 11.3 12.1
Oxidation 46 ---
TAN --- 2.5
TBN 5.27 12.2
1st column: Current, 2nd column: Abn
Iron 16 150
Nickel 0.0 5
Chromium 0.6 20
Titanium 0.0 ---
Copper 9.6 155
Aluminum 3.0 40
Tin 2.8 10
Lead 0.0 50
Silver 0.2 2
Wearcheck's comments:
CONTAMINATION
There is a light concentration of water present in the oil. Test for glycol is negative. Suspect possible water condensation is present or water from engine wash.
OIL CONDITION
Oil Type: ESSO XD-3 EXTRA 0W30
The oil is no longer serviceable due to the presence of contaminants
WEAR
All component wear rates are normal.
The condensation is due to the fact this car is only driven at highway speeds -99% of the time. The engine never warms up to proper operating condition. The thermostat temperature is 2 or 3 notches below normal and if you touch the top of the engine right after one of the ~1 hour drives it is fairly cold.
Do you guys think this oil could have gone longer if the condensation was not present?
Silicon 21
Potassium 0.9
Sodium 3.4
Fuel Glycol NEG
Water 0.179%
Soot ---
Sulfation 54
Nitration 53
Boron 3.3
Barium 0.2
Calcium 3108 3800
Magnesium 25
Molybdenum 2.8
Sodium 3.4
Phosphorus 918 1350
Sulfur 3191
Zinc 1157 1500
Visc@40°C --- 71
Oxidation 46 ---
TAN --- 2.5
TBN 5.27 12.2
Iron 16 150
Nickel 0.0 5
Chromium 0.6 20
Titanium 0.0 ---
Copper 9.6 155
Aluminum 3.0 40
Tin 2.8 10
Lead 0.0 50
Silver 0.2 2
CONTAMINATION
OIL CONDITION
WEAR
