Original Enzo Post:
10/2007:
This is my neighbor’s 2003 Ferrari Enzo with a total of 8,800 miles on the left column and my 2003 Enzo with a total of 3,000 miles on the right column (middle column as of today-2009). Both cars had 1,400 miles on the oil. His obviously had more break-in time. He had the oil changed by the Ferrari dealer using the required 10W60 Shell Helix Ultra Racing oil. I ran 0W30 Castrol GC.
The recommended interval is 5,000 miles, less if on the track. This is strictly off track use in town and on the highway, probably 50-50 for his car and 90 percent city for me.
His oil was tested by: www.youroil.net, while I got the full, total evaluation from Terry Dyson at www.dysonanalysis.com.
7/2009:
Another 1,400 miles on the Enzo now with 4,400 miles, still not broken in fully. When I took out the GC I put in 0w30 RLI. This is what we are testing here today. Again, tested by Dyson. Remember that his testing counts larger particles as well as all the smaller ones so other labs may give false lower values.
My driving has been exclusively in town and most often back and forth from Home Depot for small items. Just before this sample was taken we drove to the Ferrari dealership in Tampa to test drive the new Ferrari California. Going there and back took a total of 2.5 hours or so and about half of the way back it rained (very hard).
So the fuel dilution was probably much higher before this short trip. At no time has the oil temperature in this engine gotten above 180 F. This oil has been in for nearly two years but Terry Dyson says I should just keep going (and going and going).
What is particularly interesting is that I put in 0w30 RLI and the viscosity (with probably even a lesser dilution after this trip) is in the 20 grade area now. Remember that a 60 grade oil is spec’ed.
2/2/2012 Current Report - Last, 4th, right column:
Well it has been over 2 years so I changed the oil even though it only had another 1,000 miles on it. This report is for the new “improved formula” that was labelled “Dr. Haas’ Enzo Formula” from RLI. Working with Bill Garmier over at RLI the formula was tweaked to the Enzo’s apparent needs, or maybe I should say “my” needs/wants.
I believe this formulation has been perfected and am considering it’s use in all my cars. I am not sure my wife will allow such a thick oil in her Murcielago however.
_____________Shell..GC..RLI...RLI - “Dr. Haas Enzo Formula”
Iron___________ 32...11...7...3 (Fe in RLI VOA =2)
Chromium ______ Nickel __________ 2...1....0...0
Aluminum ______ 11...3....2...0
lead ___________ 16...0....3...1
Copper _________25...8....4...3
Tin ____________ Silver _________ Titanium _______ Silicon __________ 7...3....4...2
Boron __________ 1...3....16..17
Sodium _________ 8...3....10...8
Potassium ______ Molybdenum ____ Phosphorus ___1026...935..1032..698
Zinc ________ 1135..1228..1055..988
Calcium _____ 1454..167..2108..1898
Barium _______ Magnesium ___1219...526..53..19
Antimony _____ Vanadium ______ Fuel %Vol _____ Flash_______not done..335..320..300
Abs Oxid ______ 34...10..127...95
Abs Nitr _______ 11....8....8....7
Wtr %vol ______ Vis CS 100C __ 15.8...11.8...8.6...9.8
Vic CS 40C___not done..66...44...48
SAE Grade _____40....30....20....30
Gly test ______NEG...0.37 “not antifreeze”....0...0
TBN _________not done...7.9....5.9...6.4
TAN _________not done...1.7....1.4...1.3
Visc Index_____not done..154...177...192
Soot__________not done...0....0.01....0
aehaas
10/2007:
7/2009:
aehaas
