OVERKILL
$100 Site Donor 2021
Ford hybrids ( Escape ) were shared with Toyota . Not sure if they still are .
Ford and Toyota shared patents on hybrid tech is my recollection, they didn't actually share the hybrid system.
The start buttons have been reliable, more so than the fobs... and a WHOLE LOT more than the electric parking brake buttons. Replacing those are a near daily experience...
So my point is, if a button is reliable for 1 brand, the button doing the same thing on another brand might not be. And maybe the button a few inches away is the total opposite...
Appreciate it. I had thought of maybe doing an electrical class at the community college to get a better understanding of the electrical systems and everything. I mostly understand what you wrote but some of the more advanced problems I usually need the most guidance with.That's Ohms law and when working on car electrics it's THE law. Gets a bit more complicated for AC but generally also true there.
to use this in the starter example. Say your battery has 12V and the starter draws 100 amps. (1.2 kw starter) . That means the starter has 0.12 ohms resistance of it's own. With that extra 0.1 ohm resistance there, current drops to 12v/0.22 ohm or 54 amps. And voltage splits over both resistors so your 1.2 kW starter is only seeing 6.54V... 6.54V x 54 amps = 353 watt... or just over 1/4th rated power.
I myself have not replaced a push start /stop button but it looks like it would be a lot less effort.That's definitely not the case... at least not on hyundais. Needs coding aswell which a key cylinder doesn't if the old keys can be reused, or the transponders switched over.
Adds a lot of internal engine wear from my days in the Dynos. Had to update the bearings in the Pentastar to get it to pass testing. As an OCD engine design guy, I shut it off. Saw too many bad things at the teardown reviews and on the CMM's. Screw the starter...I felt for those poor bearing surfaces! haha
Well said. No matter how well people might think the system upgrades made to accommodate the start/stop system an engine is better left running than shut down and restarting every single time a car comes to stop, even if it is only for a few seconds. Screw that, if I owned one I'd let the engine run. My bet is after 100K miles I'd have a hell of a lot less wear than the same car driven the same way using stop/start. I don't believe for one minute that the technology is better for the engine, sorry no way.That is the major wear point when using these systems, this was the reason as I understand it for specially coated bearings. This is IMHO an agenda driven piece of worthless over complex trash technology and destined to go the way of automatic seat belts with no start feature which were another agenda driven tech.
I'm familiar with the changes. I'll go with what the experts here have to say. IIRC @OIL_UDDER actually worked for Chrysler on the Pentastar engine team. Imagine if you allowed the stop/start designed engine to just run instead of the constant stopping and starting. Less annoyance, less chance of a malfunction, and you might just have an engine that can easily last a lifetime w/o a rebuild.Stop/Start systems aren’t as potentially damaging as cold starts, though, simply because the engine isn’t cold. Not only are the engines at operating temperature before the stop/start system begins to work, the vehicles also use electric water pumps to maintain optimal engine temperature when they’re stopped. If the engine is off long enough to reduce engine temperature significantly, the engine will automatically restart.
Secondly, while the engine’s oiling system isn’t completely pressurized as it when it’s running, the oil in the passages hasn’t been allowed to completely run down into the oil pan.
Finally, suppliers are addressing wear with dry lubricants on components like main engine bearings. Engine bearings are typically designed to withstand 100,000 start cycles. New bearings are now in use that are designed to withstand 250,000 to 300,000 start cycles. Federal Mogul, for example, has been incorporating polymers on the connecting rod bearings for cars with auto-stop/start systems to reduce friction when oil isn’t pumping.
Does Auto Stop-Start Technology Wear Out Engine Components?
Now that most new cars have auto-stop/start technology, are our vehicles becoming more vulnerable to engine and component failure?bestride.com
I don't think anyone is deathly afraid of it, I just think it's a stupid idea, and something I'd rather not have rammed down my throat as some great technology. As long as I can easily disarm it, I'll own it when the time comes. Reading through almost ten pages here, I'm in good company. Maybe if I lived in an area where traffic was not like Long Island or NYC I'd feel differently. But when a 20 mile commute to NYC can take me 2 hours or more, [sometimes a lot more] stop/start that can't be disabled easily, is a big no thanks! And a problem waiting to happen.There are many other things that will break before a start/stop motor-IMHO.
This topic is just a strings of "new tech" topics (that really isn't "new tech" anymore) that the guys on here are deathly afraid of.
One bad motor design by a company-doesn't make an example.
Yes....on BITOG you would be in good company. This same type thread has been repeated even with safety features that save lives such as collision avoidance, ABS systems, and the like. All these are/were "shoved down our throats". Of course- stop/start is "only good" for saving resources-not a high priority for some.
One can go back through the history to see all the features that came along but had no input from consumers. The automatic transmission, automatic choke, and a list as long as my arm. Some even fade away and we make jokes of them like the push button transmission. Now it has made a comeback in the past several years. Nobody makes the jokes anymore.
Remember when power brakes and power steering were the latest thing?
