My 2011 Scion tC has been suffering from an all-too-common problem that seems to affect almost all of Toyota's new engines: A rattle at startup due to a faulty VVTi mechanism. I've had my car in to two different dealers where I have successfully duplicated the issue only to be told that it's normal cold-start noise. A representative of Southeast Toyota even inspected my car and gave me a similar-sounding answer, telling me that the noise is "normal." Here is what it sounds like.
It's obvious to me, however, that this is not the case as Toyota has a TSB out for the exact issue I'm experiencing that covers all affected Toyota vehicles. Scion has no comparable bulletin even after over a year of the new tC being on the market. I've been experiencing this issue since around a month or so of ownership which is absolutely unacceptable for a brand new car.
I'm supposed to be meeting with the same SE Toyota representative sometime in the near future to have him look at the car again, but I don't have my hopes up that anything will be fixed. By refusing to even acknowledge the issue I believe Toyota has found a way to prevent lemon law from applying since I believe it requires them to at least attempt to repair the car before it can come into play. I believe this issue is diminishing the value of the car as much as it diminishes my pleasure in driving it and I want Toyota to either fix it or buy it back. Does anyone have any advice in getting Toyota to do something about it?
I should add that this is only one out of several issues going on with the car; the build quality seems to be nothing short of abysmal.
