The car does not stay in warm-up enrichment for long, guys. I can watch my AFRs and my closed/open loop status real-time. On a cold start these days (high 20s Farenheit to low 30s), I'm in open loop enrichment (~14:1 Air:Fuel) for about 20 seconds.
That's right, 20 seconds. That surprised me a lot. At this point, the heated oxygen sensor is good to go and it performs it's tests (the car runs from full rich to full lean in b>
I'm not sure exactly how Honda does it but I tune my F-150 cold start by changing the cold start table A/F and duration. I changed my injectors also and the tuning program had the new values needed. Do you have a wideband F/A meter and datalogging capability? Have you done any dyno runs to see where you're at. If you aren't fueling about 11:1 at WOT and backing down the spark you could have problems.
