Originally Posted By: bepperb
We're talking about classic cars, which are generally seldom driven and mostly in nice weather. The benifits to a synthetic oil such as cold weather starting and a longer OCI aren't relevant to the demograpic you're writing to. Not that it would even matter because you don't point them out in your article anyway.
Although the
Engine Oil article is written for the classic car owner, I don't believe that I have written the article as specific advice for antique and classic cars only. If you re-read my Oil Recommendation section, I do recommend extending OCIs to coincide with tire rotations.
As for the low temperature advantages of synthetics, thank you for bringing this to my attention. Although I have mentioned it indirectly, I will have to add more information in this regard. It is the first draft after all and there is plenty of room for improvement.
The benifits of a 0w-x are even more suspect in this application. Are classic car owners interested in fuel economy during short trips when the engine doesn't get up to full temp? Are they really having starting problems in a car designed for straight 30? Are you overinflating the importance of getting an oil to operating temp viscosity to try to sell oil?
Based on what I've read from Widman and Haas, many people seem to
underinflate the importance of getting an oil to operating temp viscosity. Do you disagree with Widman's
Corvair Oil article or Haas'
Motor Oil Basics article?
