- Joined
- Dec 28, 2014
- Messages
- 3,023
It really depends on the car manufacture and driver. I think most Toyota’s and Honda’s, Lexus, will go 200,000 easy without major repair. 300,000 with some work.
I have taken a Honda Accord to 289,000 miles before selling it. I imagine it made it past 300,000, but it took some work. Don’t let anyone fool you, it takes work. I replaced almost every suspension part TWICE, maybe three times. I replaced the steering rack, subframe, gas tank, engine mounts (twice), countless mufflers and exhaust pieces, a bunch of sensors, brake lines, calipers, calipers again, a few gaskets, a radiator, an egr valve, and probably ten things I’m forgetting.
I took an LS460 to 178,000 miles before it started drinking oil and needed $4,000 worth of work (that I didn’t want to do because the interior was falling apart and the engine was consuming 5 quarts of oil between changes).
We have a Honda CRV with 142,000 miles on it. Not ONE single issue with that thing. Nothing. I can’t believe it. Not one check engine light, misfire, brake issue, steering issue, suspension part replaced. Nothing. Just change the oil every 5,000-6,000 miles and general fluid changes.
Meanwhile I bought a 2018 Chevy Silverado brand new and put 50,000 easy up and down the highway miles on the thing...replaced a starter, towed out of my driveway, had a check engine light (cylinder 5 misfire), oil consumption from day one, torque converter shutter, Chevy shake, transmission seemed like it was utterly confused at all times (despite two transmission services). Frame was rusting before I even drove it off the lot...crawled under it when I got home...rust all up and down the frame because GM’s frame wax already was coming off. Other than that...yeah, I actually liked the truck.
