I have to do some drilling into metal. Advice is to use a a cutting oil, Kroil or transmission fluid. I have some engine coolant, could I use that?
Thanks
Any kind of engine oil will do also, 3 in 1 is better than nothing. Run the bit a slower speed to reduce heat.
Coolant used for cutting tools contains water soluble oil, grinders can use straight coolant.
What? You don't like the smell of Prestone in the morning?
That's right there with packing the front bearings with bacon grease.
