I have read thru the service manual for coolant change. The procedure by toyota involves racing engine to above 3000 rpm to place system in fill mode, and repeat 3 times.
With the understanding of how the system works, I am proposing the following alternative, main reason is to avoid racing engine to 3000 rpm at no load condition:
Disconnect the electric connectors on the two coolant bypass valves. This ensures the coolant go thru the heater core and atf cooler. Then use a scantool to raise water pump speed, to say 2000 to 3000 rpm, add repeat 3 times ( let pump rest for a minute or two in between.
What do you think?
Scan tool does not seem to have a function to enable fill mode, but it does have the ability to command the water pump.
What do you think?
