Energy/Resource conserving oil not allowed? Why?
China
Honda not allowing Energy/Resource conserving oil to be used on its scooters, e.g PCX and Forza 350. Don't know if it is the case for non-scooters.
Mobil AFE is Energy/Resourse consering. But I can't see any specs different from other oils, e.g EP/ESP...
Why? If I go ahead with AFE, does it damage the engine or what?
Honda not allowing Energy/Resourse consering oil to be used on its scooters, e.g PCX and Forza 350. Don't know if it is the case for non-scooters.
AFE and ESP have lots of different specs.
Not sure if Honda scooters use a wet clutch, but this is common in motorcycles.
Honda not allowing Energy/Resourse conserving oil to be used on its scooters might be due to specific friction modifiers which could cause the wet clutch to slip.
I've ridden 7500 miles on a couple PCX's over the years. I've almost exclusively used a 10w30 that is resource conserving. Don't worry about it for a second. Dry clutch means no worries here.
Energy Conserving will not damage your engine because Energy Conserving is not
additive... its an API mileage test that this "oil MAY result is an overall saving of fuel
in the vehicle fleet as a whole" there is nothing in the oil to defeat a wet clutch...
I've been using EC oil since 98 in my Honda RC45 with no oil related problems...
Jealous of that bike!!
why "some"?
which ones?
So not all oils that fit API energy conserving?
Idk man that’s just what I’ve been told
I’m sure you could dump energy conserving oil in and be fine but that’s not what the manufacturer recommends doing as it could cause problems
Mileage is chief factor that determines when your clutch is about to
slip not whether the oil is Energy Conserving...
Technically speaking there is nothing in EC oil that will defeat a wet clutch in good working
ordered... mileage not additives is the cause of our clutches to loose grip...
High mileage is the constant where all clutches begin to loose grip
due to normal glazing and contaminates that build up over use...
I haven't seen an energy conserving additive identified by anyone in the industry. If it's not showing up on an analysis, then it's magic pixie dust and would someone, do tell, what that magic pixie dust would be. Energy conserving simply went to lighter weight oils in my opinion and that virtue alone contributed to fractionally increased gas mileage and it stuck.
This has been my experience as well. I've used EC oils in all manner of off-road and dualsport bikes without issue.
I have always been of the opinion that it has more to do with CAFE and environmentalist nonsense.
