My 98 Sienna is sitting on 8035 miles. My plans were to go to 10-12k on this oil. These plans are no more. I didn't chicken out. Read on if interested -
I have had an off forum discussion with BITOGr Mokanic - a Toyota Master Tech. I believe he has correctly discerned my oil consumption issue, and I am planning to proceed immediately with his suggested (non-intrusive) remedy.
I am burning one qt of rather expensive oil in the first 1k miles of an OCI, and 1 qt in subsequent 1.7k (this consumption rate has only appeared in the last couple of years). My compression is fine - I'm still getting the stated mpg for the van. So the compression rings are fine. Mokanic says Toyota engineered the oil rings for minimal wear on the cylinders (very low tension rings), the downside to this is that my 8-9k OCIs (even with Synth) have apparently gummed them up. BTW, a Toyota mech recently verified that I had no engine leaks.
So the Mokanic recommended cleaning process will begin immediately. I was planning a UOA at the end of this OCI. If someone can give me a good reason to do one at this pt, I would consider that. But I presently don't see it as worthwhile - my original fill of M1 EP 5w30 has had 3 qts of EP added to it and now 2 qts of 0w40. The UOA at 4.2k was fine except for an above average Fe. So the only thing a UOA at this pt would tell me is, does M1 (mainly EP) have an upward trend on Fe wear. BUT, I am not planning to ever revisit the M1 EP or reg. lines - so it's not worth $22.50 to Blackstone to answer this trivia question.
I'm thinking out loud here - but I'm wondering if this is the first part of the cascade that gells these engines. Blazing hot (areas of the) engine leads to deposits that gum the oil rings that lead to quick consumption that exacerbates step one above, etc. This thing eventually gummed them (assuming Mokanic is right) on a pure diet of M1 Tri-Synth and SuperSyn (albeit, slightly extended OCIs).
